Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
Edelbrock Supercharger tune problem......
Old Sep 6, 2012 | 10:10 PM
supermod's Avatar
supermod
Default Edelbrock Supercharger tune problem......
Bought my 07 Saleen Heritage from a Ford dealer, I didnt get the tuner with the car. My dyno guy says says I need to take it to Ford, have them flash back to stock, then tow the car back so as not to operate with a stock tune. Then he can use a aftermarket tuner. If Id only known....... Sounds like an expensive pain in the ***.
Old Sep 7, 2012 | 08:18 AM
Doogie65's Avatar
Doogie65
Taking it back to the dealer is the only way to get the stock tune restored, but if you have the base supercharger configuration, you could always just download that tune from Edelbrock. This tune requires the stock airbox, 3.8 inch pulley, stock exhaust and stock fuel system... along with a Diablo tuner.
Old Sep 8, 2012 | 08:04 AM
supermod's Avatar
supermod
Thanks, Doogie. I have the 3.8 pulley, Saleen exhaust catbacks,and stock fuel system. Ill call Edelbrock on Monday and check it out. Thanks again
BTW, why the GT500 fuel pumps? Mine seems like its lean on top(pulls harder at3/4 throttle than WOT) . I would like to bring the boost up to 10lb but Im sure it would need a custom tune for that.
Old Sep 9, 2012 | 06:06 PM
Doogie65's Avatar
Doogie65
I added the GT500 pumps when I swapped in the 3.5 inch pulley, which did require an update tune. Anything from the base configuration will require a custom dyno tune. Any change to your current set-up including a smaller pulley to up your boost would require tuning changes.
Old Sep 10, 2012 | 11:32 AM
jpplaw's Avatar
jpplaw
Brenspeed has a good 3.5" pulley tune. Thats what I run
Old Sep 10, 2012 | 11:43 AM
Doogie65's Avatar
Doogie65
Based on your mod list, I would assume your Brenspeed tune is fairly customized.
Luke9222
Oct 22, 2015 11:55 PM
Gene K
Oct 21, 2015 11:37 PM
MasterLanMan
Sep 26, 2015 10:03 AM
Sep 3, 2015 07:14 PM
