v6 engine conversion
Old Mar 13, 2006 | 07:40 AM
fielddoc00's Avatar
fielddoc00
Default RE: v6 engine conversion
I am in the middle of dropping a 5.0 in my 2000 V-6 and believe me when I say it is quite a lenghty process. I can't comment on the cost because I had a 93 GT donor car given to me, but the following has to be changed: K-frame, motor mounts, ecu, ecu wiring harness, fuel system (according to the engine...the 99 to 04 is a returnless system) and fuel pump. I am on my 4th week of the project now.
Old Mar 13, 2006 | 11:36 AM
mustangman02232's Avatar
mustangman02232
ORIGINAL: jthorn9
To lazy to read all of that, but remember, you should get forged internals, a ported sytem, and a cam for forced induction.
why?[&:]
Old Mar 13, 2006 | 12:02 PM
tightdogal's Avatar
tightdogal
ORIGINAL: fielddoc00
cool! let us know how you do with that, sounds muy interesante
Old Mar 13, 2006 | 12:25 PM
jthorn9's Avatar
jthorn9
The Godfather
Because, 1.) you'll get a bigger power gain, and 2.) you know that your internals will be more than fit for the extra strain that will be added onto them, it's not 100% neccessary to do, but really should be done if you don't want to run the chance on blowing a stock piston, piston ring, or rod.
Old Mar 13, 2006 | 02:42 PM
mustangman02232
ORIGINAL: jthorn9
more $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Old Mar 13, 2006 | 03:25 PM
jthorn9's Avatar
jthorn9
The Godfather
Yea, that to.
Old Mar 14, 2006 | 03:32 AM
p0rsche23's Avatar
p0rsche23
i dont see it running 3000+ to do the swap,id say a used 4.6,if u get one outta the 99-04s then hmm i dont know how much a salvage yard would charge u for it but id say u could prolly get one 1000-1500 if u wait around and look alot.....then u can do the swap urself,buy the parts u need,wiring harness,pump,a/c lines i think,i dont think the extra parts will run over 1000,so 2500max prolly around 2000 if u get used stuff or find good deal on a wrecked one....
but i do agree that spending 2 to 3 grand u can up that v6 u got to be a gt killa......i think those turbo kits and eveyrthing to go with em would run up to 4-5000 though....IMO if u get a good deal on a wrecked gt then id say go for it if thats what u want and have the time and knowledge to do it....
Old Mar 14, 2006 | 07:47 AM
mustangman02232
ORIGINAL: p0rsche23
really, how many people do you think on here know how to screw around with the wireing and computer, then you need motor mounts, a rear end, driveshaft, suspention, mise well swap some GT or mach guages in since thats the engine they are made to read off of.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Nov 10, 2015 11:39 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
