audio help...
Old Mar 19, 2006 | 07:30 PM
murphy_07's Avatar
murphy_07
Default audio help...
no before everyone gets on my case about it being in the wrong place, lemme just say that i dont feel like getting told to "replace my mach 460 system" or how "the 460 sucks" now with that out of the way, i have bought a brand new alpine 9855 deck for my car. i bought the necessary wiring harness to hook it up. it gets a full display which is a good thing, and it also produces bass through my sub system, however, no vocals, music, or sound is comming out of the speakers what so ever. now i had this same problem with my explorer that had premium sound, and i had to do an "amp bypass" now i think i have to do the same thing to my stang, but i am not for sure, i could use some insight please.
Old Mar 19, 2006 | 08:52 PM
03YellowPony's Avatar
03YellowPony
Default RE: audio help...
ORIGINAL: murphy_07
Try posting this question in the Audio section. Maybe the guru's can help ya better there.
Old Mar 19, 2006 | 09:22 PM
ByPopularDemand's Avatar
ByPopularDemand
Did you say you do have an amp. When I thought I had a big problem I just had a bad connection
Old Mar 20, 2006 | 02:16 PM
lilnicky068's Avatar
lilnicky068
i know exactly what your problem is. mustangs have external amps for their speakers. you know that purple "remote" wire you hook up to your sub amplifier??? you need to splice into that and have that run to your factory amp too. i had the same problem and after a bunch of troubleshooting, finally found out that was the problem.
Old Mar 20, 2006 | 02:19 PM
alexr's Avatar
alexr
do all stangs have factory amps? or do the older ones just run off of the power the head unit supplies... if thats possible?
as much as i know about electronics, car audio is just a notch over my head.
Old Mar 20, 2006 | 02:23 PM
lilnicky068
yes all mustangs have external factory amps. if you are hooking up a new head unit, you have to make sure to connect that remote wire to the factory amp or you will get no sound. the remote wire turns the amp on/off when you start/turn off your car. i would recommend just bypassing the factory amp though. having 2 amps creates distortion.
Old Mar 20, 2006 | 05:05 PM
alexr's Avatar
alexr
hmm thats odd. i installed an aftermarket head unit myself and i didnt have to splice the remote line. and it works perfectly fine.
Old Mar 20, 2006 | 06:09 PM
lilnicky068
you dont have to splice it if you dont have a subwoofer amp. i was just telling him to splice it because he will need one wire going to his sub amp and one going to his factory amp
Old Mar 20, 2006 | 11:50 PM
murphy_07's Avatar
murphy_07
but which amp? i have 3 factory amps (two in the back and one underneathe the cd deck itsself)
Old Mar 20, 2006 | 11:51 PM
p0rsche23's Avatar
p0rsche23
i bypassed the one factory amp i had behind my stock radio.
