Quick octane question
Old Mar 27, 2006 | 07:59 PM
mustangman02232's Avatar
mustangman02232
Default RE: Quick octane question
ORIGINAL: TorchV6
Did you ever think maybe there was no difference because you may have driven faster or worse when you were using the 93? Because I personally notice everytime that I use a higher octane that my mpg goes up 1-2.
ORIGINAL: mustangman02232
ORIGINAL: jthorn9
Well I'm gonna say try it, you won't be able to notice the hp gain you'll get, but you will probably notice a slight mpg increase and you will notice that your engine will run better. Trust me, I think you can afford $1.50 extra at the pump, and that's if you fully have to fill up. If you don't like it, or don't notice anything, then drop back down to 87, but I think you may like 89, now its 93 octane that you may have a slight problem with, but I'm still pretty sure your spark plugs generate enough spark to fully detonate the gas, but try 89, if you like it, try it for a while, and when you're really feeling experimental, try 93.
oh Bull, ive done all kinds of different mpg tests going back and forth to maine, there is NO difference except i had less money after putting in premium
when the cruise gets set at 60 then no, speed is not a factor
Old Mar 27, 2006 | 08:00 PM
Derf00's Avatar
Derf00
Gentleman's Relish
does your car ping or knock? is it tuned for premium? if you answerd no to both of these questions they stay with regular, thank you come again
+1
Old Mar 27, 2006 | 08:02 PM
TorchV6's Avatar
TorchV6
doesnt matter if you are using cruise or not when you are accelarating
Old Mar 27, 2006 | 08:19 PM
mustangman02232
ORIGINAL: TorchV6
1.) i accelarated about the same, keep it below 2k rpm by babying the throttle till 30, set the cruise and then accelerate by the CC
2.) it would be a bigger diff then .6 mpg i would think
Old Mar 27, 2006 | 08:24 PM
TorchV6's Avatar
TorchV6
.6mpg where are you getting that? I said 1-2mpg also I dont need to argue with you because I know what I have calculated and the different things I have tried if you dont believe me then that is your own prob. I am just suggesting for this guy who had a question.
Old Mar 27, 2006 | 08:32 PM
mustangman02232
ORIGINAL: TorchV6
yes, and i am saying that driving very similarly on both 93 octane and 87 octane i got .6 mpg diff between using the two, and i had the windows up and the AC on both ways, cruise set at 60 accelerating gentally, overdrive on, me and my dad, and sister with 2 overnight bags and a back pack in the back
Old Mar 27, 2006 | 11:57 PM
jthorn9's Avatar
jthorn9
The Godfather
Well I noticed about a 2mpg increase before I tinkered with the spark advance, so technically my engine wasn't tuned to 93 and I got way better engine responce and mpg, yes 2 mpg is a lot for me. Also, your car gets way worse milage than most of us here, so consider your airflow problem a factor to.
Old Mar 28, 2006 | 12:01 AM
ace1986's Avatar
ace1986
ive tried 87 and 89 and got no difference in milage and before i gave my car a tune up i was only gettine 15mpg and now i only get 17mpg with my 2.3L
Old Mar 28, 2006 | 12:13 AM
jthorn9's Avatar
jthorn9
The Godfather
Damn that's horrible, I get around 26-28 mpg on the intersate, and I still manage around 18-20 in the city.
Old Mar 28, 2006 | 12:15 AM
ace1986's Avatar
ace1986
im talking city sorry i should of been spacific with mine and interstate i get like 22-24 mpg highway
