Clicking Noise
Old Apr 20, 2006 | 12:48 PM
zarins04stang's Avatar
zarins04stang
Default Clicking Noise
on my way to skool this morning i noticed that when i made a turn (right or left) i kept hearing a kind of clicking noise, and its gettin me worried. anyone have any idea on what the problem is and how serious it is?
Old Apr 20, 2006 | 12:56 PM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: Clicking Noise
Take it to a shop, that may be serious. Go to Firestone, Ford, or some other suspension/tire shop immidiatly after school, last thing you want is for somthing to break and cause you to get in a wreck.
Old Apr 20, 2006 | 01:15 PM
ecuadorspimp's Avatar
ecuadorspimp
that happened to me before. i had hit a pothole and caused some damage. it broke like a stabilizer link and i had to get it changed. pretty easy if you got a jack and some hand tools. the piece only costs like 10 bucks. But def get it checked out.
Old Apr 20, 2006 | 01:56 PM
HRnB's Avatar
HRnB
Administrator
Could be as simple as a loose brake pad, or it could be a loose wheel or bad wheel bearing.
First try to figure out which wheel it is coming from with the help of a friend. Next jack up your car and get the effected wheel in the air. Next pull the wheel side to side and see if you have any slop. If you do, you need to slightly tighten your axle bearing nut just enough to take out the slop, but the wheel still spins freely. If it doesn't have any slop, then start rotating the wheel. If you spin the wheel and you hear the clicking, it's more than likely a bearing. If it is a rear wheel, you will need both wheels off the ground and the trans in neutral, also release the E-brake. Make sure your car has a block under the wheels that are on the ground so it doesn't roll.
Before you go buy a wheel bearing, take off the wheel where the noise is coming from, and grab your brake caliper and give it a good shake. It should be tight with no movement. If it does move at all, it could just simply be a loose caliper. Also examine your brake pads to make sure you don't have a broken or bad pad.
Old Apr 20, 2006 | 01:57 PM
jthorn9's Avatar
jthorn9
The Godfather
Sorry for the whor post, but love the new sig booz.[8D]
Old Apr 20, 2006 | 02:15 PM
HRnB's Avatar
HRnB
Administrator
Thanks JT, JonBeast made it for me.[sm=smiley20.gif]
Old Apr 20, 2006 | 03:01 PM
zarins04stang
thanks a lot for the feedback guys, ima go check it out this afternoon
Old Apr 20, 2006 | 06:02 PM
TorchV6's Avatar
TorchV6
are you sure it wasnt your turn signal [sm=lol.gif]
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
KingRando
69Volunteer
Sep 30, 2015 10:39 AM
gagemcc
Sep 22, 2015 09:43 AM
