running rough
Old Apr 23, 2006 | 04:33 PM
johnwads's Avatar
johnwads
Default running rough
my 2.3 4 cyl is running rough also sometimes almost no power barely goes 30 mph wiht throttle to the floor then it just lets loose and runs well thought it might be the cat but not the prob still does it.. at times the idle just goes way down.. soemtimes stalls any ideas? thanks
Old Apr 23, 2006 | 05:13 PM
Krusher's Avatar
Krusher
Default RE: running rough
ok, year, mileage, recent maintenance/upgrades/whatever, and a simple digital picture of your engine compartment would help.
Old Apr 23, 2006 | 05:16 PM
johnwads's Avatar
johnwads
92 125,000 got the car a few years ago needed trans.. did all the plugs wires etc. changed one coil pack for the drivers side of engine code says.. left side bad... isnt that the one i replaced? see if i can get a pic on here had probs doin that in the past
thanks for any info
Old Apr 23, 2006 | 05:21 PM
Krusher's Avatar
Krusher
yeah, left is driver's side.
running rough without a code has a specific pinpoint procedure... namely checking in this order:
1) Fuel system (injectors, fuel pump, lines)
2) secondary ignition system (spark)
3) mechanical (compression, valve seating, etc)
Old Apr 23, 2006 | 05:23 PM
johnwads's Avatar
johnwads
sorry code was 218 which the book describes as Ignition system problem loss o f left side ignition diagnotstic monitor signal
which means?
Old Apr 23, 2006 | 05:27 PM
Krusher's Avatar
Krusher
was? does that mean that you pulled the code, cleared it after the repair and it worked fine until just now... or you pulled the code and repaired and it hasn't really been fixed yet... and the code is yet to return, or has it returned?
Old Apr 23, 2006 | 05:43 PM
johnwads's Avatar
johnwads
just pulled the code today
no repairs since
Old Apr 23, 2006 | 07:07 PM
Krusher's Avatar
Krusher
alright, I won't get much but I might get a little information from oasis about the problem from ford... but I need your VIN.
Old Apr 23, 2006 | 07:19 PM
johnwads's Avatar
johnwads
vin 1FACP1MSNF159981
not sure if the 1's are 1 or l probably 1
thanks in you cant help guess i'll have to take it to someone with a puter to test it more..
Old Apr 23, 2006 | 07:27 PM
Krusher's Avatar
Krusher
that's only 16 numbers... vins are 17
