Cams?
Deffinitly worth it, if you can afford it with all of the supporting mods, like injectors, maf, and a port and polish job. http://www.rpm-mustangs.com/ has a wide variety of cams, you'll be able to find what's right for you there.
Mik at www.rpm-mustangs.com can help you
also Tom Yentzner of www.supersixmotorsports.com can help too as will Tom Morana of www.moranav6racing.com
yes it is well worth it. a cam alon on a V6 can ad 30rwhp and with ported heads and intakes make up to 70hp over stock depending on setup
contact Justin Starkey at www.vmptuning.com for tuning needs
Damn, how in the hell is a 20-30 hp increase, with a cheap little $200 cam, with the options of having the entire intake ported and polished, to produce upwards of 50 hp, for under 2K, not worth it, especially considering that s/c and t/cs cost upwards of 3.5K and will only add as much hp as your mods support, which can be anywhere from a 40% increase to 65% or so at best.
Well thanks for everyones veiws...but I have been thinking about it and I'm with Jthorn...I think i just gonna do cam for nowand do heads and everything on a later date...I think the stock injectors should be able to handle Just the cam, but will eventualy need changing...Hopefuly I will get this done over the next couple months...I'll let everyone know how it goes
junior04
Sep 28, 2015 10:53 AM
