when will it STOP!?!
Old May 2, 2006 | 12:35 AM
stangthang824's Avatar
stangthang824
Default when will it STOP!?!
my car is making too much noise. it seriously sounds like a zoo under the hood. there's hissing, chirping (not only the barring but i think its something with the alternator as well because when i revv it gets worse and worse). ehhhh mustangs suck sometimes...actually fords in general suck sometimes. does anyone know what the hissing sound could be? it sounds like my car is on god damn life support or something....help=(
Old May 2, 2006 | 01:05 AM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: when will it STOP!?!
Did the car throw a check engine code
Old May 2, 2006 | 03:23 AM
Galaxie's Avatar
Galaxie
Is it a hissing or like a whining almost like a loose belt noise....cause my alternator started doin that recently....at first i thought i might be power stering or sumtin to do with pulleys but i pin pointed that it was coming from the back of the alternator with a mechanics stethescope...If anyone has ideas on this i would also appreciate it...
Does anyone else have noise coming from there alternator?
Is there sumthing to change in the alternator or do you just have to replace it>?
Old May 2, 2006 | 05:18 AM
zarins04stang's Avatar
zarins04stang
ORIGINAL: stangthang824
maybe u got Cold Air Intake and u dono about it haha jk
Old May 2, 2006 | 04:19 PM
stangthang824
my check engine light has always been on due to some air malfunction. when i revv the engine with the hood up it sounds kinda like one of those cord ***** in a whistle...it's hard to explain. i probably have the same problem you do.
Old May 2, 2006 | 04:38 PM
Galaxie's Avatar
Galaxie
Sounds quite a bit like my issues...I think I am just gonna try replacing the alternator for now and see how that goes...Once I get around to it I will let you know how it goes, if in fact that was all it was
Old May 10, 2006 | 12:58 PM
stangthang824
i just dont understand how the alternator is the part going bad out of all things? i know it controls like the main electric functioning of your car and none of my other parts are bad?...someone explain. and keep it simple=)
cr620
Oct 3, 2022 10:18 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
trashxtrash
Sep 20, 2015 10:49 PM
IronRaptor
Sep 9, 2015 08:10 AM
