Little Help Regarding Temp.
Old May 6, 2006 | 02:45 PM
gxszone's Avatar
gxszone
Default RE: Little Help Regarding Temp.
No i haven't changed it, but if you suggest I should then I will - they are less than 20 dollars anyways
Old May 6, 2006 | 04:39 PM
Autobadges.com's Avatar
Autobadges.com
Banned
you absolutely need to change it. If you haven't changed that by now that should have been STEP 1 of the process...as its the cheapest and easiest ones to swap and usually the main culprit of overheating..next to the radiator and no coolant. Sometimes they don't open as 'prompt' as they should when they are dying...which would look like almost overheating
serge627
Apr 19, 2006 01:30 AM
UZIboy420
Apr 17, 2006 12:55 PM
UZIboy420
Apr 14, 2006 02:47 PM
badazz68stang
Mar 12, 2006 09:48 PM
Marauder8
Mar 1, 2006 04:07 PM
