air intake Q
Old May 16, 2006 | 08:53 PM
crocop's Avatar
crocop
Default air intake Q
i was on mustang world.com and some guy made a homemade cold air intake system using some sort of tubing and brackets i was just wondering wat the outcome of that would be like any thing the same compared to the reall system? also i keep reading all these fourms that say different things so i want to clarify. about the air silencer is it recommended to take it off, like does it waste gas more. and also i want to put a k and n filter in and the bracket that it sits on the 3.8 is supposed to be removable well i cant seem to get it out can any one help me there thanks
Old May 16, 2006 | 08:55 PM
Rook6's Avatar
Rook6
Default RE: air intake Q
bracket? You mean the air filter housing?
Old May 16, 2006 | 10:42 PM
crocop's Avatar
crocop
yes the air housing
Old May 17, 2006 | 12:53 AM
Rook6's Avatar
Rook6
First unscrew the one retaining bolt. You'll see it securing the filter housing to the right fenderish area inside the engine bay. (5/16" wrench'll do it)
Second, there are two latches that secure the filter housing to the mass air, one clearly visible on top of the housing, and the other along the side between the engine and the housing. Undo both of them.
Now, there are two rubber grommets that sit in two holes beneath the housing, keeping it set. Pull UP to unset the grommets, then OUT (towards the driver's side) to clear the silencer from the fenderwell. Then just pull the sum-bich up (you may need to angle it a bit, but you'll get it easy) and take the housing off.
Replace the filter and do all that backwards to resecure everything.
I hope this is what you were talking about or I'm gonna feel like a dumbazz for going into all that detail.
EDIT: This is...also assuming that you have a 99-04 V6...lol, though I think it's the same on the earlier SN95s as well
Old May 17, 2006 | 01:34 AM
SXGT's Avatar
SXGT
i use dto have this crazy idea to take out my fog light and run a pipe from there to the intake, like a ram air set up.
Old May 17, 2006 | 01:46 AM
Rook6's Avatar
Rook6
You and me both, bud....you and me both.
Old May 17, 2006 | 02:15 AM
00StangV6's Avatar
00StangV6
ive seen this thing at auto zone where u can do that, its like a flexible hose that u can run from any where to the air filter. cost like 10 bucks i think, but i think u gotta buy there air filter to make it work right, thats like 20 bucks.
Old May 17, 2006 | 02:20 AM
michaelbarry's Avatar
michaelbarry
[quote][You and me both, bud....you and me both.
/quote]
And me. I think they did it on tv though, or someone was telling me they did. I'm not sure what show it was though.
Old May 17, 2006 | 04:46 PM
crocop's Avatar
crocop
wat about that homemade cold air intake is that any good or wat
Old May 17, 2006 | 07:47 PM
StickShifty's Avatar
StickShifty
ghetto
