need help
Old May 20, 2006 | 03:01 AM
Dolph's Avatar
Dolph
Default need help
I need help with 2 basic things on an 89 hatchback.
1. My headlight covers have water in them and have started to turn yellow. I'd like to remove them empty the water and clean them, but I need to know how to remove them. I know it must be simple, but I'm not sure which screws need to be removed (or if some clamps just need to be removed.
2. Also, my hatchback refuses to be shut completely. The part on the hatchdoor itself that locks around the bolt doesn't easily slide to snap onto the bolt. I've tried putting wd-40 on the latch, but it still doesn't move as easily as I think it should. If I remove the latch and manual slide it on the bolt, it works, but I must press it down hard. While attached to the hatch, when I shut the door, the interior light goes out (so it comes close to closing) but no matter how hard I push down I can't push it down over the bolt enough.
Any help will be appreciate.
Thanks in advance.
Old May 20, 2006 | 03:04 AM
93BlackNotch's Avatar
93BlackNotch
Default RE: need help
You can buy a new 6piece headlight kit for $120 shipped to your door... They are worth their weight in gold... It really cleans the car up... I got mine from
www.cjponyparts.com
[IMG]local://upfiles/34557/F0B08A5633AE42DE879D805BC7E5917A.jpg[/IMG]
