Engine Noise
Old Jun 2, 2006 | 05:28 PM
Red3's Avatar
Red3
Default Engine Noise
OK, my engine is making this ticking noise when under throttle. The higher the RPM's the louder it gets. You can't really hear it at idle but once you get around 1500-2000 it becmoes really noticeable. Under hard acceleration you can't really hear it that much, I think because of the sound of my exhaust, but I have also noticed recently that depending on the temp outside and the temp of the engine also will determine how loud it is and stuff. If it's cold and all then it's not as loud as it is when it's hot out. Any idea's on this??
Old Jun 2, 2006 | 05:41 PM
mustangman02232's Avatar
mustangman02232
Default RE: Engine Noise
where is it coming from, could be an exhaust, a nail/screw in the tire, a lifter sticking, few other things
Old Jun 2, 2006 | 05:51 PM
Red3's Avatar
Red3
A couple friends said they think it might be a lifter. They said they don't think it's an exhaust leak cuz it gets louder the harder I press down on the pedal. It's def not the tire thing cuz it does it when I'm in N and the car is stopped it does it if I rev it. My dad said he thinks it's coming from the passenger side.
Old Jun 2, 2006 | 05:57 PM
mustangman02232
front or rear?
Old Jun 2, 2006 | 06:01 PM
Red3's Avatar
Red3
Front. It is def coming from under the hood. It's kinda hard to tell cuz it doesn't really do it as bad as it does when I'm moving but maybe it's cuz when I'm parked I don't just hold the throttle at like 2500 rpm's
Old Jun 2, 2006 | 06:04 PM
mustangman02232
check and see if the oil is low, it could just be a loud lifter, but it could be sticking, do you have a stock or aftermarket exhaust though?
03YellowPony's Avatar
03YellowPony
ORIGINAL: Red3
Try this...remove the oil filter and dump the oil out. Then reinstall it. Top off the oil with TRANSMISSION fluid. Run it a week or so then change the oil. This is an old mechanic's trick. Tranny fluid is just a very high detergent oil. This will usually clean the system, including the lifters. If it works, you're out the cost of a quart of tranny fluid, and all is well. If not, you may still have a sticky lifter, or some other thing. Also, add a big bottle of Techron to the gas tank in case you have a sticky fuel injector. When you do that, I recommend filling up the tank with Chevron or Shell SUPREME. Both of those already have Techron added, (Shell calls it V Power, but it's TECHRON) and you are giving the system a double shot.
Old Jun 2, 2006 | 06:05 PM
mustangman02232
ORIGINAL: 03YellowPony
ORIGINAL: Red3
ya that will work, and harv check your PMs i got a question for you on a completely different motor though
woot 4000, im catchin up to ya harv
Old Jun 2, 2006 | 06:10 PM
03YellowPony
ORIGINAL: mustangman02232
ORIGINAL: Red3
ANSWERED...
And you will NEVER catch me! wOOt!!
Old Jun 2, 2006 | 07:32 PM
tims 88 4's Avatar
tims 88 4
trans fluid in the motor??????????? thats crazy ive never heard of that i put in my power steering id be willing to bet that its a lifter
