EDIT: DO IT!!!!!!!!!!!!!!!!
Old Jun 11, 2006 | 07:47 PM
penceman's Avatar
penceman
Default RE: DONT DO IT (My Bad Luck)
ORIGINAL: Verado
Damn that sucks man. What kind of paint did you use??
Some kind of 1200 degree spray paint.
Old Jun 12, 2006 | 12:44 AM
flash20's Avatar
flash20
well at least u got threw and it looks nice
Old Jun 12, 2006 | 11:07 AM
Jefferson's Avatar
Jefferson
Moderator
I did mine yesterday too. Here is a pic.
[IMG]local://upfiles/17695/165FB9641EE34F31ADD5B548669A66F3.jpg[/IMG]
Old Jun 12, 2006 | 12:55 PM
penceman's Avatar
penceman
ORIGINAL: Jefferson
Did you use a kit or something? And I guess you used a paint brush, right?
Old Jun 12, 2006 | 01:22 PM
Jefferson's Avatar
Jefferson
Moderator
Nope, the kit is like $70, I though I'd try the spray bomb first as the 2 cans only cost $12. Im making a write up on it, should be up tomorow. It has lots of fun pics.
Old Jun 12, 2006 | 02:12 PM
Dirtysouthstang's Avatar
Dirtysouthstang
i want to do it but im to lazy and i dont have the day to two to wait for it to dry but i when i get my new wheels, probibly the end of the summer
Old Jun 12, 2006 | 02:14 PM
Jefferson's Avatar
Jefferson
Moderator
Spray bomb takes 10 min between coats, 30 min to dry to the touch and 24 hrs to dry fully.
Old Jun 12, 2006 | 02:41 PM
P Zero's Avatar
P Zero
I dont get what took so long to replace the studs. On MOST cars, especailly the ones where the bearings and the studs are in the rotor, are especailly easy. And if the studs were too big for the holes then you got the wrong studs. Hoggin out the holes so you can fit em isnt a good idea either.
-P.
Old Jun 12, 2006 | 03:02 PM
cwall583's Avatar
cwall583
Well it looks good! So I guess it was worth it.
Reminds me of the old saying, "when you're hip deep in alligators (replacing studs) it's hard to remember the original objective (painting the calipers) was to drain the swamp." It's always the unexpected problems that cost me the time as well.
Old Jun 12, 2006 | 10:15 PM
03zx2's Avatar
03zx2
my wheel studs got cross threaded too last week. one of the lug nuts wouldn't come off because the stud was moving, took 4 hours with a drill to drill it out. then i got a new hub assembly and the studs were already in there. took 20 mins or less after the intial 4hours to get the one nut off.
