Brake?
Old Jun 12, 2006 | 01:12 AM
Justinv6's Avatar
Justinv6
Default Brake?
Sup! Hey my name is Justin, and i drive a 2000 v6, silver with true duals. I ve had my mustang for almost a year now and just recently the brakes have been acting up. The problem is when i press the brake slightly i dont hear anything and there are no weird sounds while i driving. THe only problematic sound i hear is when i apply the brakes to the floor there is this really horrific grinding sound! I assume it is just a bad break pad but i thought it wouldn't hurt to ask....
Old Jun 12, 2006 | 01:17 AM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: Brake?
Does the brake light come on every now and again too
Old Jun 12, 2006 | 01:18 AM
03YellowPony's Avatar
03YellowPony
Default RE: Brake?
ORIGINAL: Justinv6
GET YOUR BRAKES CHECKED...Sounds like you may be getting REALLY close to metal to metal...if not already there...
Old Jun 12, 2006 | 01:21 AM
bain_bk's Avatar
bain_bk
Default RE: Brake?
grinding is a bad sign, could be messing up your rotors
Old Jun 12, 2006 | 01:36 AM
86_GT_Mustang's Avatar
86_GT_Mustang
Default RE: Brake?
yea rotors could be bad by now hope not tho
Old Jun 12, 2006 | 02:59 AM
Jimmz's Avatar
Jimmz
Default RE: Brake?
If this has been going on for a while you will most likely have to have ur rotors turned or replaced, if you do go with this kit.... Mustangtuning.com, I did this conversion and I am very happy with it, I got it from a friend of his cobra for free and all I had to do was get the rotors turned....
Old Jun 12, 2006 | 01:21 PM
flash20's Avatar
flash20
Default RE: Brake?
yeah u should get that looked at before anymore damage comes
Old Jun 12, 2006 | 01:58 PM
tightdogal's Avatar
tightdogal
Default RE: Brake?
if you can feel the grinds when u apply the brakes, that means ur hittin metal on metal. most brake pads are engineered to squeak when they start getting low. so if ur hearing and feeling a grind, stop driving on that and get that checked out asap.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
