Refcounter
Old May 7, 2004 | 01:04 PM
Maxtor's Avatar
Maxtor
Default Refcounter
The refcouter of our 1985 LX Convertible 3.8 V6 isn't working, does anybody knows what to do to make it work? Is it a broken cable or something? And if it is the cable where can I find the cable in the car?
Old May 11, 2004 | 01:44 PM
Maxtor's Avatar
Maxtor
Default RE: Refcounter
Nobody?
Old May 15, 2004 | 12:54 AM
VertStangGT86's Avatar
VertStangGT86
revcounter? as in tachometer? If that's what you're talking about could be a bad or disconnected cable.
Old May 15, 2004 | 03:47 PM
Maxtor's Avatar
Maxtor
With refcouter I ment the meter ho shows the rpm per minute. Where can I find the disconnected or broken cable? Where in the dashboard and were on the other site (gearbox??, and were on the gearbox??), and is it a nasty job to replace the cable?
Old May 15, 2004 | 07:47 PM
Dan04COBRA's Avatar
Dan04COBRA
It's called a Tachometer, not a Refcounter.
Old May 15, 2004 | 09:07 PM
Ftr-Speedy's Avatar
Ftr-Speedy
the wire from your tach goes to the ignition coil i believe, negative side. well if u gotta take the dash out then ya its gonna probably be nasty job unless u know what your doing. and as for where in the dash board the wire is, my guess would be right behind your tach. maybe just take it to a shop and get it down.
Old May 17, 2004 | 03:44 AM
VertStangGT86
Oh yea, would be a wire wouldn't it, good call on my part[8D]
Old May 19, 2004 | 03:09 PM
SilverGTV8's Avatar
SilverGTV8
Well first it's a tach not a refcounter, second it is a wire not a cable, third it doesn't connect to your gear box but to your ignition.
I would recommand getting a Haynes manual for your car that should help you out. It could be broken anywhere, but chances being it is either at the TACH itself or in the engine compartment.
Oh it doesn't count your rpm it tells you.
