Engine Problem
Old Jul 14, 2006 | 06:23 AM
02 Stang's Avatar
02 Stang
Default Engine Problem
I have a 2002 V6 Mustang, stock engine, Mello-Tone dual exhaust is all I have done engine-wise. My car idles roughly when I am at red lights, stop signs, in traffic, or in line at a fast food place. The only way I can really describe it is a jump. My car will idle normally, then drop under .5 RPM's and rise above 1.5 RPM's... We've brought the car in to the dealership numerous times, and every single time they say they have fixed it the problem comes back within 20 or so miles of driving the car. It is a continuous problem that I can't seem to solve. Does anyone here have any suggestions on what to do and how to fix this? Any feedback would be greatly appreciated!
Old Jul 14, 2006 | 09:49 AM
03YellowPony's Avatar
03YellowPony
Default RE: Engine Problem
ORIGINAL: 02 Stang
How many miles on the car, and what have you done to try to solve the problem so far?
Old Jul 14, 2006 | 12:20 PM
02 Stang's Avatar
02 Stang
ORIGINAL: 03YellowPony
ORIGINAL: 02 Stang
A spot over 47,000 miles on it and so far to correct the problem I have done nothing other than bring the car into the dealership... It get's really old having to pay them to do nothing though. If need be I can go into my glove compartment and tell you for sure what they have done from the reports I've been given.
Old Jul 14, 2006 | 12:22 PM
02 Stang's Avatar
02 Stang
Also, why won't my signature show up in these posts?
Old Jul 14, 2006 | 12:46 PM
Stang562's Avatar
Stang562
have you tried checking up on the fuel injectors?? i had a similar problem also and it turned out it was just that
Old Jul 14, 2006 | 12:47 PM
jthorn9's Avatar
jthorn9
The Godfather
You've got to go to you profile, edit your sig, then all the way at the bottom click apply. My bet is that it's the maf. My car did the same thing and if baffled several mechanics as to the problem. Make fun all you want, but this "GENIUS" here is the only one smart enough to say, hmm, maybe it's the maf, and lord and behold, guess what it was, the maf. Mine had an electronic malfunction that caused it to read totally improperly. So bring it back to ford and tell them to take a look at that. If it's not that, then it could be anything from a stupid burnt out fuse to a bad spark plug.
Old Jul 14, 2006 | 12:48 PM
02 Stang's Avatar
02 Stang
ORIGINAL: Stang562
Excuse my limited knowledge of a working engine, but how would I go about doing this? I'm here to learn
Old Jul 14, 2006 | 12:50 PM
02 Stang's Avatar
02 Stang
ORIGINAL: jthorn9
And now the question, what's the MAF and how do I check it? Glad to hear you're car is running fine now, but I want mine too! lol the problem with bringing it back to the dealership currently is that because of Katrina they will have to have my car for at least 3 weeks because they are so backed up, So I was hoping I could possibly correct the problem at home. If not I will bring it back to Don Bohn though.
Old Jul 14, 2006 | 12:57 PM
jthorn9's Avatar
jthorn9
The Godfather
Actually that problem was on my old 98 sixer, the car in my sig is a 95 GT for which I've already dumped around 3K in repairs, thank God I'm done, I hope. Ok best way I can say this is to click on my photo album and then click on my engine pics for my 98 V6. You'll see a little aluminum tube about 5" long just behind the first bend of the cold air intake. This little tube will also have a black box ontop of it with a wire that runs into the fender well. The little black box is the mass air flow sensor (that's what went out) but to fix that, the mass air meter (that little tube) has to be pulled and the whole thing has to be replaced. The MAF sits in the backside of your airbox in behind that little black wall looking thing behind your air filter. Only real way to check it is have Ford run diagnostics on it.
Old Jul 14, 2006 | 01:00 PM
jthorn9's Avatar
jthorn9
The Godfather
Could also be the injectors like someone else said. Go to any Wal-Mart or gas store and get some fuel injector cleaner. Poor the whole thing into your gas tank, and then fill it up with gas. Now if you have a bad injector, that won't help much, but it will help clean out any crud stuck inside the injector.
