Starter Question
Old May 21, 2004 | 02:50 PM
e40water's Avatar
e40water
Default Starter Question
I just put my new starter in my 83 stang 3.8L, I noticed the ring gear looks like a tooth could be chiped, I wondering how hard it is to change it?
Old May 21, 2004 | 06:25 PM
MelloYello's Avatar
MelloYello
Default RE: Starter Question
Ring gear?
Are you talking about one of those planet gears? Or theres a stationary gear, and in the drive assembly
Old May 21, 2004 | 07:19 PM
HRnB's Avatar
HRnB
Administrator
Damn, I hope he's not talking about the flywheel. [sm=smiley21.gif]
Old May 22, 2004 | 04:17 AM
e40water's Avatar
e40water
on the old starter, the small gear on the one that connects to the flywheel, I found out that why it was causing my car to hard to start, I just replaced that whole starter/
Old May 22, 2004 | 04:11 PM
HRnB's Avatar
HRnB
Administrator
ORIGINAL: e40water
Yup, thats the way to do it.
Old May 25, 2004 | 12:25 AM
VertStangGT86's Avatar
VertStangGT86
The teeth on the flywheel are stronger then the starter ones so if something goes wrong you won't **** up the flywheel. Also the ring gear is in your rear end not up there with the starter.
Old Jun 1, 2004 | 03:30 PM
e40water's Avatar
e40water
its the the ring gear is the flex plate the little starter gear run onto the ring gear of the flex plate, Just a weird question, What happens is over years the engine heat warps the flex plate and causes the starter gear to not fuction properly. Ive got it taken care of thanks guys.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
logan409
Sep 26, 2015 07:43 PM
