Clutch or Transmission problem?
Old May 30, 2004 | 04:05 PM
cpopp's Avatar
cpopp
Default Clutch or Transmission problem?
I have a 98 Mustang V6 with Manual transmission.
I recently had the whole clutch assembly and flywheel replaced. After this repair, I started having problems getting into 1st gear. The shop said it might be a stretched clutch cable and replaced that. Now it's even worse.
When I'm in 1st gear and starting from a stopped position, the car shakes violently like if a person was trying to start from 5th gear. If I push in the clutch just a bit, it will sometimes stop lugging and shaking. I'm also starting to have problems getting the car our of reverse.
What is the problem? Did the shop mess up? Am I losing my 1st gear in the transmission?
Old May 30, 2004 | 05:10 PM
e40water's Avatar
e40water
Default RE: Clutch or Transmission problem?
first I am thinking youre shifting rods could be bent, Have you drivin youre stang agressively before you got youre new clutch put in?
Second I am thinking youre clutch bearing release may need replacing sometimes they over look at that.
Old May 30, 2004 | 05:39 PM
cpopp's Avatar
cpopp
I'm not an aggressive shifter... braking maybe, but not shifting.
I'm pretty sure they also replaced the clutch release bearing, but I'll have to double check.
Old May 31, 2004 | 01:00 AM
VertStangGT86's Avatar
VertStangGT86
bottom line is if you took it in for the repair then it started doing this take it back and tell them to fix it. If they're a good shop they'll check it out, if not they may tell you to screw off and say you can't prove it's their fault.
Old Jun 1, 2004 | 03:25 PM
e40water's Avatar
e40water
Yea thats true, The guys at the shop could have bent one u never know, I would take it back to them.
Pyrate Dave
Sep 10, 2015 07:30 PM
Roush05
Sep 10, 2015 12:23 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
