Fuel pump question...
Old Jul 30, 2006 | 07:53 PM
MyStangStanks's Avatar
MyStangStanks
Default Fuel pump question...
So, I've been looking in some people's signatures, and I've noticed that they're using the Focus SVT fuel pump. Why are you/they using them? And why on a Mustang?
Old Jul 30, 2006 | 08:32 PM
3.8blackout's Avatar
3.8blackout
Default RE: Fuel pump question...
not an expert on FI but ill give it a shot. with FI, im pretty sure that more fuel is being pushed into the engine to compensate for the air that is also being forced into the engine. without a larger fuel pump (the SVT focus pump can push alot more fuel than the stock mustang one can i believe), the engine would run lean or it would put alot of stress on the stock pump, and thats a bad thing AGAIN... im just guessing and im no expert on FI or fuel systems for that matter lol, sorry if im wrong or partially correct.
Old Jul 30, 2006 | 08:38 PM
MyStangStanks
ORIGINAL: 3.8blackout
AIght cool thanks. So would it be ok to use it on an NA, or would it just be a waste of money and a horrible reduction of MPG?
Old Jul 30, 2006 | 08:56 PM
3.8blackout
i really dont know lol, youd be better off waiting for a more experinced member that actually has the focus pump.
Old Jul 30, 2006 | 08:57 PM
MyStangStanks
Aight. Thanks anyways! Hey you don't do sigs, do you?
Old Jul 30, 2006 | 08:59 PM
Jugador's Avatar
Jugador
the focus pumps flow 143lph from what ive read. i don't know what a v6 mustang has stock but it could be lower. i do know that adding a higher flow fuel pump when it doesn't need the extra fuel is just a waste. save it for when you have the airflow to necessitate more fuel. if you don't need bigger injectors, you probably don't need a bigger fuel pump
Old Jul 30, 2006 | 09:09 PM
MyStangStanks
OK Thanks!
Old Jul 30, 2006 | 09:30 PM
3.8blackout
i dont do sigs, no, but i did make mine.
Old Jul 30, 2006 | 10:16 PM
MyStangStanks
OK thanks anyways.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
