PCV valve
Old Aug 18, 2006 | 10:36 PM
v6stang07's Avatar
v6stang07
Default PCV valve
Can anyone tell me where to find info on replacing the PCV valves in my car or tell me where they are and how to do it.
Old Aug 20, 2006 | 03:42 AM
nitrous36's Avatar
nitrous36
Default RE: PCV valve
Its located on the valve cover. On 94-04 V6s its on the driverside valve cover. All it does is remove pressure and harmful excess gas ( caused by from combustion) from the engine through a vacum. Now I have few questions too. How do you know if its the PCV valve (and not the exhaust) thats responsible for the ticking sound every1 asks about? And if it is should it be replaced?
Old Aug 20, 2006 | 04:21 AM
cobra232's Avatar
cobra232
ORIGINAL: nitrous36
94-04 PCV valve is on the passenger side valve cover towards the rear, not the drivers side. the drivers side is a breather to allow air in when the engine sucks gasses out through the PCV
on 99-01's the PCV allowed excess oil to be sucked into the intake causeing detonation and heavy oil deposits on the intake valves which can cause more valvetrain noise and hurt gas mileage.
you can either make an oil trap by basically adding a T-connector in the line and attaching a small plastic bottle to grab the oil or just delete the PCV by ading a breather filter in it's place. keep the pcv and line and put it back on to pass visual emissions inspection
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
lmurf60
Sep 24, 2015 10:07 PM
