short throw install
Old Sep 1, 2006 | 01:22 AM
2001 mustang v6's Avatar
2001 mustang v6
Default short throw install
does anyone by chance know where the link for that is..i searched for it but couldnt find anything. im a button away from buying the steeda tri-ax but i wanna know about installation first.. any help would be appreciated, thanks.
Old Sep 1, 2006 | 01:28 AM
JoJo96Vert's Avatar
JoJo96Vert
Default RE: short throw install
I know jthorn just did his a few weeks ago, see if you can track him down. Or autobadges can help you out I'm sure, along with a few other people on here. Those are just the first few that came to mind.
Old Sep 1, 2006 | 01:29 AM
jthorn9's Avatar
jthorn9
The Godfather
Click my sig for the best place to buy a steeda short shift.
1.) Put the car in neutral
2.) Unscrew the shifter *** and take it off
3.) Pop off the plastic pannel around the shifter, the boot will come up with it
4.) Take out the two bolts that holds the upper half of the stock shifter to the lower half
5.) Unscrew the 4 bolts at the bottom around a copper looking plate
6.) Unscrew the 4 bolts that holds the sifter onto the tranny
7.) You'll really have to pull, but pull off the stock shifter
8.) Make sure that the plastic cup that fits around the ball of the stock sifter is still in it's little hole, if it comes out with the sifter, take it off and put it in place
9.) MAKE SURE YOU GET THE GASKETS FROM AUTOBADGES.COM TOO, put the big gasket in place
10.) Put the steeda shifter in place
11.) Put the 4 bolts that hold the shifter to the tranny back in place
12.) There are two screws on the short shifter, put the shifter in third and tighten down on the screw until it's on the shifter (or stops screwing) back it out 1/6th of a turn, do the same for 4th gear
13.) put the copper plate back on
14.) put the upper part of the shifter on
15.) put on the plastic cover
15.) rescrew in the shifter ***
16.) ENJOY.
Old Sep 1, 2006 | 01:30 AM
2001 mustang v6
thanks alot for the instructions
Old Sep 1, 2006 | 01:34 AM
jthorn9's Avatar
jthorn9
The Godfather
No problem, now CLICK ME to get your Steeda Short Shift.[8D]
Old Sep 1, 2006 | 03:41 AM
2001 mustang v6
hahaha
Old Sep 1, 2006 | 05:36 PM
02ponypackage's Avatar
02ponypackage
The shifter should come with instructions plus STEEDA's website shows pics on the install...putin my TriAx in was 1,2,3 and is better then that Pro5.0 shifter
Granatelli Sales
Jan 20, 2020 12:34 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 3, 2015 07:14 PM
cbird1177711
Sep 2, 2015 08:51 PM
