help! 94 mustang mods
hey, i am back again leaving another post cuz i didn't get much response before. i am looking for improvements of ANY kind that will help my 'stang perform and look badass! thanks for the help guys, i really appreciate it.
Air Intake
1.) MAC Cold Air Intake $170 @ autobadges.com
4.) 80mm Cobra MAF set to 24lb injectors
5.) 56mm BBK Throttle Body $249 @ V6mustangstuff.com
Engine
1.) ASP 25% Size Reduced Crank Pulley $72 @ autobadges.com
2.) Billet Aluminum Water Pump Pulley $65 @ rpmoutlet.com
3.) ASP Underdrive Pulley Belt $35 @ autobadges.com
4.) Diablo Predator Tuner 96-04 $399 @ hillbankmotorsports.com
5.) BBK Chrome Valve Covers $329 Silver $199 @ hillbankmotorsports.com
6A.) Stage 2 (AUTO) Powerpack $1725 @ supersixmotorsports.com
6B.) Stage 2+ (MANUAL) Power Pack $1950 @ supersixmotorsports.com
6C.) Stage 2+ (AUTO W/STALL) Power Pack $1950 @ supersixmotorsports.com
6D.) Stage 3 (FORCED INDUCTION) Power Pack $2375 @ supersixmotorsports.com
6E.) Basic Split Port Intake Swap Kit $720 @ rpm-mustangs.com
6F.) 99+ Stage 2 (AUTO) Powerpack $1800 @ supersixmotorsports.com
6H.) 99+ Stage 2+ (MANUAL) Power Pack $2200 @ supersixmotorsports.com
6I.) 99+ Stage 2+ (AUTO W/STALL) Power Pack $2200 @ supersixmotorsports.com
6J.) 99+ Stage 3 (FORCED INDUCTION) Power Pack $2350 @ ssms^^^
6K.) Split Port Swap Gasket Kit (no intake or heads) $310 @ rpm-mustangs.com
8.) 24lb Fuel Injectors $279, 30lb $275, 42lbs $359 @ jegsperformance.com
9.) Stud Mount Adjustable Roller Rocker Arm Kit $495 @ supersixmotorsports.com
10.) Cam Thrust Spacer Roller Bearing Kit $150 @ supersixmotorsports.com
11.) Spring Retainer Kit $225 @ supersixmotorsports.com
12A.) Forged Stock Internals $1200 @ supersixmotorsports.com
12B.) Forged H Beams W/ 351W Rods $1600 @ supersixmotorsports.com
13.) BBK Fuel Pressure Regulator $109.99 @ brothersperformance.com
Forced Induction
1.) Nitrous Oxide approx $500 @ jegsperformance.com and many others
2.) Vortech Supercharger approx $3500, see vortechsuperchargers.com for info.
Ignition
1A.) Red/Blue/Yellow 9mm Spark Plug Wires $70 @ autobadges.com
1B.) Chrome 8mm Spark Plug Wires $100 @ autobadges.com
2.) see msdignition.com for the rest of your ignition needs
Exhaust
1A.) JBA Silver or Titanium Short Tube Headers $640.97 @ hillbankmotorsports.com
1B.) JBA Short Tube Headers $460.72 @ hillbankmotorsports.com
1.C) JBA Chrome Short Tube Headers $349.99 @ brothersperformance.com
2A.) 2.5†V6 O/R X-Pipe see pypesperformance.com
2B.) MAC 2.5†V6 O/R H-Pipe $160.50 @ hillbankmotorsports.com
2C.) 2.5†V6 High Flow Catted X-Pipe see pypesperformance.com
2D.) 2.5†V6 High Flow Catted H-pipe see pypesperformance.com
3A.) Magnaflow 2.5†GT Cat-Back Dual Exhaust $469.99 @ brothersperformance.com
3B.) Borla 2.5†GT Cat-Back Dual Exhaust $699.99 @ brothersperformance.com
3C.) Bassini 2.5†GT Cat-Back Dual Exhaust see bassini.com
3D.) Flowmaster 2.5†GT Cat-Back Dual Exhaust see flowmaster.com
4.) MIL Eliminators (for O/R systems only) $61.95 @ hillbankmotorsports.com
Drivetrain
1A.) Ford Racing Posi-Traction 7.5†Differential $199 @ v6mustangstuff.com
1B.) See drivetrainspecialists.com for more durable options
2A.) 3.73 Motive Performance Plus Gears $ 149.99 @ mustangtuning.com
2B.) 4.10 (Moderately Moded Apps Only) Motive Performance Plus Gears $149.99 mt
2C.) 3.73 Ford Racing Gears $199.99 @ v6mustangstuff.com
2D.) 4.10 (Moderately Moded Apps Only) Ford Racing Gears $209.00 @ v6ms
3.) Motive Bearing Kit $74 @ mustangtuning.com
4.) 23 Tooth Speedo Corrector -
Transmission Auto
1.) High RPM Stall Torque Converter see mustangsunlimted.com
2.) Shift Kit see mustangsunlimted.com
Transmission Manual
1.) Steeda Tri-Ax Short Shifter $179 @ autobadges.com
2.) Shifter Gasket Set $9 @ autobadges.com
3A.) Spec Stage 2 Clutch $333.95 @ mustangsunlimited.com
3B.) Spec Stage 2+ Clutch $399 @ mustangsunlimited.com
3C.) Spec Stage 3 Clutch $499 @ mustangsunlimited.com
Suspension
1.) Steeda Caster Camber Plates $229.95 @ autobadges.com
2.) Steeda Lower Control Arms $295.95 @ autobadges.com
3.) Steeda upper Control Arms $295.95 @ autobadges.com
4.) Steeda Lower Subframe Connectors $89.95 @ autobadges.com
5.) Eibach Pro Spring Kit $224.95 @ autobadges.com
6.) Tokico D-Spec Shocks $629 @ autobadges.com
7.) Ford Racing (Cobra) Break Kit $819.88 @ mustangsunlimited.com
8.) 17†or 18†Rims see tirerack.com
Body
1.) Body Kits see mrbodykit.com, cervinis.com
Interior, Exterior, and Under Hood Visuals
1.) See mustangsunlimited.com, mustangtuning.com, and autobadges.com
Engine
Forced Induction
Ignition
Exhaust
Drivetrain
Transmission Auto
Transmission Manual
Suspension
Body
Not all of it, but it's damn close. For stroker kits you can also see http://www.rdmotorsports.com/ as well as http://www.supersixmotorsports.com/ and http://www.rpm-mustangs.com/
ORIGINAL: jthorn9
Air Intake
Engine
Forced Induction
Ignition
Exhaust
Drivetrain
Transmission Auto
Transmission Manual
Suspension
Body
Air Intake
Engine
Forced Induction
Ignition
Exhaust
Drivetrain
Transmission Auto
Transmission Manual
Suspension
Body
Air Intake
Engine
www.vmptuning.com has 42lb injectors for alot less
the pullies are the only worth while mod if you only want to add 8rwhp
the BBK Valve covers are not worth the money or the effort to make your own oil baffles and use Felpro gaskets instead of the garbage ones they supply
Diablo = junk SCT Xcal2 custom loaded for your car by Justin Starkey from www.vmptuning.com is a much better idea
short tube headers are worthless unless you are running 15psi on a blower. the ford T-lok is junk.
you didn't list the procharger or www.tmaturbo.com
MIL eliminators rarely work. just make it smog legal in the first place as good cats really don't hurt performance.
please don't mind my critique
well he never said these are the very best things you can get for the MOST power out of your car, he made the list for himself and posted it to help people they are HIS choices.
inyadreems
Aug 21, 2015 09:10 AM
Aug 12, 2015 05:39 PM
. . . Brooklyn Man!
