Dash Light Problem.
Old Jul 13, 2004 | 01:18 AM
Mantra Locust's Avatar
Mantra Locust
Default Dash Light Problem.
Hello all,
I'm experiencing a problem with my Dash Lights. I've checked the fuse, and there isn't anything wrong with it. I've also fiddled around with the light switch, but that didn't help either :/ What I find odd is, when I pull the light switch to cut my lights on (which work fine) my Clock gets really dim, but none of the dash lights work (dash, A/C, Ash Tray Lights). The only thing I've done today was put a new battery in, I don't believe I've done anything to short it out. Any help will be greatly appreciated. Thanks!
Old Jul 13, 2004 | 04:26 AM
e40water's Avatar
e40water
Default RE: Dash Light Problem.
maybe the bulbs in youre dash are burning out, they may need to be replaced.
Old Jul 13, 2004 | 04:35 AM
Mantra Locust
I doubt the lights in my dash, AC, and Ashtray went out at the same time :P
Old May 1, 2008 | 11:49 AM
bmennen07's Avatar
bmennen07
i have the same problem. did u fix it yet??
Old May 1, 2008 | 06:00 PM
JKs95stang's Avatar
JKs95stang
It's probably more likely that it's your headlight switch. I just changed mine about 3 months ago and haven't had a problem since. If your dash lights aren't working, your brake and taillights aren't working either, that's how I figured out it was my headlight switch. GL
P.S It's not likely that all the bulbs went out together, replace the headlight switch, I think it was like 20 bucks or something, easy fix!! You could also try jiggling the headlight **** like I did for awhile, the dash lights will usually come on, if they do, you know thats the problem.
2015Ecoboost
Sep 17, 2015 01:48 PM
Colin Ringle
Sep 15, 2015 09:27 PM
rksnow1
Sep 14, 2015 08:46 PM
Blk Vert
Sep 9, 2015 12:16 PM
amandahchase
Sep 3, 2015 10:09 AM
