Quick help
Old Sep 18, 2006 | 04:07 PM
tommy2273boy's Avatar
tommy2273boy
Default Quick help
couple of things!
1.) when i stop short a stop light(brake hard) my steering acts very funny. It either pulls to one side...commonly the left, but today it was shaking!! and it took both hands on the wheel to keep the car in my lane. It really isnt as dramatic as it may sound, but its awfully annoying!!! and i think it has somthing to do with brakes, im almost 100% it does!!
2.) does anyone know the way to get a golf ball size dent of out your door? Its on the bottom and i think my ****head neighbor did it...i cant prove it though!!
thanks for help!
Old Sep 18, 2006 | 04:11 PM
kraz3y's Avatar
kraz3y
Default RE: Quick help
you might what to check your brake pads for wear mite have to get those changed thaT or ur alignment mite be jacked up or somthing
Old Sep 18, 2006 | 04:31 PM
hndrx1a's Avatar
hndrx1a
From what I've read, if your ride has major suspension mods-you might need a bumpsteer kit.
Old Sep 18, 2006 | 04:35 PM
P Zero's Avatar
P Zero
As far as your brakes are concerned, you probably need rotors and pads, at tbare minimum. You might also need new front calipers, when a car pulls one way or another it usually means that one of the calipers is doing more work than the other, which would indicate a siezed caliper. You might be able to get away with just cleaning and lubing up the slides, but if the piston is sticking youll need new cals.
-P.
Old Sep 18, 2006 | 06:06 PM
tommy2273boy
whoa whoa whoa!!! hold up, put somthing new on the CAR!!! omg are you nuts...that might actually make sense!!!!!
**** it, its too risky!!!!
(thanks though )
Old Sep 18, 2006 | 11:29 PM
ikewineb's Avatar
ikewineb
Pads, Rotors...I think that one is obvious. As far as the dent, there are a lot of paintless dent repair places. Depending where the dent is, they shouldn't have any trouble popping it out. The cost usually varies on the size of the dent. I would expect to pay about $75. Hope that helps.
Old Sep 19, 2006 | 12:49 AM
tommy2273boy
cool thanks guys!! ill ask about it at dealership with warranty!!
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
