Mac CAI Possible Problems
You have all the parts, this is how it installs. The straight pipe is the upper end of the pipe that goes from the mass air meter, to the intake. Now the one side of the pipe will use a blue rubbe hose to attach directly to the mam, the other side will use that elbow peice to install it to the intake. The other pipe, the L shaped one, will bolt up to the mam, and will then wrap around to the fender well. You will then need a helping hand, as you'll need to crawl partially under the car, and go in behind the fender, there's a little hole, and put the air filter up to the intake, you'll then need a buddy to put the filter on the L shaped pipe, while you hold it, and tighten it down in place. Don't forget to reinstall the IAT sensor in that little hole with the black ring in it on the straight pipe.
