check engine light
Old Aug 23, 2004 | 07:20 PM
johnwads's Avatar
johnwads
Default check engine light
in my 92 mustang 2.3 4 cyl my check engine light is on, is that on o2 sensor also my air bag light has been coming on at diff intervals, is there a sensor for that also.
any help or ideas would be appreciated
thanks john
Old Aug 25, 2004 | 02:10 PM
e40water's Avatar
e40water
Default RE: check engine light
well best thing to do is hook youre stangs up to a shop computer to find out what sensor has failed.
Good Luck.
Old Aug 25, 2004 | 08:23 PM
Krusher's Avatar
Krusher
air bag light going off in intervals = something is wrong with the air bag system... the code can be read by counting how many times it flashes between breaks and using that as a number... i.e beep beep beep pause beep beep pause pause pause means code 32.
check engine light can be anything... you need to find out the code and since you have obd1 it'll be a hassle... take it to a shop or a buddy that has a code scanner and find out what it is.
Old Aug 25, 2004 | 09:46 PM
tarpymac's Avatar
tarpymac
hey dude just take it to autozone, check engine = FREE!
[IMG]local://upfiles/6083/16B7A51CF9F749AEB7320F388B73592F.jpg[/IMG]
[IMG]local://upfiles/6083/D6A8470055B04E2DB0F72792DD5569D6.jpg[/IMG]
Old Sep 2, 2004 | 10:58 PM
bdub83's Avatar
bdub83
If everything is handling the same and your not losing power during shifts just detatch the battery terminals for 30 minutes and then re-attach it resets the computer and you should be fine I had the same problem on my 01 and nothing was ever wrong. Even after taking it to Schucks where they also did the electronics scan for free.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
