mass air sensor
what is the purpose of removing the mass air sensor? if its job is to regulate the amount of air that enters in comparison to fuel could this not set the check engine lite off. How can it be removed on a 99-04 v6?
bad idea it will f**k ur car up u have to have a air sensor telling the computer how much air and what temp air is entering the motor your car would either run so lean it may stall out at idle or run so rich it is burning gas like crazy if you want to do anything to the MAF sensor the you could try a Diablo sport MAFia it changes the signal going from the MAF to the ECU and makes the car Run richer during acceleration for better performance and then runs normal under closed throttle
thanks you guys i was confused my friend said that he removed his to boost his horsepower and i thought he was retarded cause i did not see how that could work , well i am not doing it i just got a K&N filter it seems to be more reliable thanks to all
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
