getting a 6
Old Dec 15, 2006 | 08:18 PM
mustangman02232's Avatar
mustangman02232
Default RE: getting a 6
ORIGINAL: NvRdoNeStAnGsIx
Get a 99/00 v6. What is it.. a 40 bhp difference between the years? Well worth it.
m-90 swap will net you 70 rwhp and aboot 100 rw/ft.lbs
Old Dec 15, 2006 | 08:54 PM
NvRdoNeStAnGsIx's Avatar
NvRdoNeStAnGsIx
m-90? Im confused.
Old Dec 15, 2006 | 09:17 PM
jovez's Avatar
jovez
m-90? Im confused.
m90 is the supercharger that came out on the tbird Supercoupe and the cougar Xr7 etall. with the same singleport intake that you can swap.well not exactly the same but it matches up. ( i have an m90 btw for sale if interested)
Old Dec 15, 2006 | 11:36 PM
jthorn9's Avatar
jthorn9
The Godfather
Best mods will be similar to your 5.0L, super chager (vortec is good, but the M-90 is a great deal), limited slip differential (sixers don't have them), gears, you can stroke it, port it, perform head swaps, cam swaps, N2O, pretty much anything. However going to true dual exhaust is a near must.
Check out http://www.supersixmotorsports.com/ and http://www.rpm-mustangs.com/ for some ported heads, ported intakes, cams, and stroker kits
Just go to ebay for some M-90 superchargers, although there are some sites that sell them new and or rebuilt.
Old Dec 16, 2006 | 04:04 AM
w8less's Avatar
w8less
how much rwhp do u think a rebuilt 3.8 a tma turbo kit running 8psi supersix stage 2 heads and intake and cam would make?
Old Dec 16, 2006 | 05:42 AM
w8less's Avatar
w8less
anyone have any idea about how much hp?
Old Dec 16, 2006 | 12:05 PM
mustangman02232
ORIGINAL: RyansQuick6
Just look in my sig at my performance mods, they're pretty much all bolt ons, and I can smoke even a new GT, and I don't even have a dyno tune yet. If you absolutely want a big power adder, then I suggest a s/c. They're much easier than the turbo kits and I consider them more reliable for street use, as well as power throughout the power the power band, not just a peak when it finally spools up.
Ryan
unless you have a 150 shot, try again
a TMA TT kit at 14 psi is safe on a stock motor and will put down about 400 rwhp
yes that is safe on a 100% stock motor
