do all mustangs do this?
Old Dec 16, 2006 | 12:26 AM
silverstang18's Avatar
silverstang18
I ♥ Acer
Default do all mustangs do this?
when i just get done driving my car there is something ( i was told it was condensation from heater/ AC) that leaks onto my headers it drops out a small black pipe coming from the passenger side that goes into the firewall. What is this and why does it do it? pretty much whenever i turn off my car it makes a sizzling noise its pretty loud cause its draining onto my headers.
Old Dec 16, 2006 | 12:33 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: do all mustangs do this?
All cars with a/c do this, it's called condesation. It's caused by the air box in the car being cooler than the air around which then causing moisture in the atmoshpere to condense and build up. The drain is there to stop all that water from draining onto your carpet and growing mold and ruining it. There is no fix for it, you'll probably end up with cracked manifolds before too long, it's pretty common.
Old Dec 16, 2006 | 12:39 AM
00raging stang's Avatar
00raging stang
yeh i noticed that mine does the same thing.
Old Dec 16, 2006 | 01:17 AM
90lxstang's Avatar
90lxstang
yep my dad and brother have an 02 and an 03 and they both do it
Old Dec 16, 2006 | 04:23 AM
SilvrStang's Avatar
SilvrStang
yep mine does it especially in summer time. Its condensation ,nothin to worry about
Old Dec 16, 2006 | 03:32 PM
hookedonkronik's Avatar
hookedonkronik
Actually it is something to worry about. My manifold is cracked like every other mustang out there because of this exact problem. When I replace them which i'm doing very soon i'd like to try to make it last so does anyone know anything you can do to prevent this? Like making some type of shield so water goes somewhere besides the manifold, like on the ground. Or is there a type of material for headers you can get, like ceramic, that wont be vulnerable to this annoying problem?
Old Dec 16, 2006 | 03:52 PM
silverstang18
I ♥ Acer
very cool i want to know the same thing anyone?
Old Dec 17, 2006 | 07:08 PM
RyansQuick6
Reverse Gear Member
Well, my manifolds never did crack, but I now have long tubes with a good ceramic coating, and the a/c still drips on them. AS to wether they will hold up or not is just to be seen over time. I would assume that they would do a little better, but I have seen headers crack under many other conditions. Most people just have their stockers welded up.
Ryan
Old Dec 17, 2006 | 07:14 PM
jj84756's Avatar
jj84756
yeah a good ceramic coating or wrapping would prevent it. mine aren't cracked either though.
Old Dec 17, 2006 | 07:15 PM
ionlygot6's Avatar
ionlygot6
yeah mine does this, i realized after slamming the dorr like twice its done... kinda annoying, but it happens
