Steering Not Working Right
I changed the rack and pinion on my car and just got it aligned but when i brake or hit A BUMP THE CAR GOES ALL OVER THE PLACE. IT FEELS LIKE THE STEERING WHEEL IS POSSESSED!! it just pulls and its a serious issue. Could it be the ball joints?? or something to do with the steering column?? I need help badly!!
Like I said.. I had the same problem. Replaced my ball joints, steering has been TIGHT ever since. Warning though, if you replace the ball joints you MIGHT need to get it re-aligned again. I didnt, but it is a possiblity. Look to spend about 50 bucks on the balljoints and 200 on labor, unless you do it yourself. Its probally an allday job for your shadetree mechanic.
True.. but my tie rod ends were fine other then my outter tie rod end on my passenger side making noise. I replaced it anyway.. im a picky person when it comes ot noises on my car.
Yes i think its the ball joints. Me replacing the ball joints and the tie rod end were on 2 seperate occasions. When I used to hit bumps, my car would jerk HARD to the right, almost throwing me off the road. After replacing the balljoints, my car hits bumps and the steering wheel doesnt even move. Its so much smoother.
so tomorrow im changing my ball joints and my bushings for the control arms. any particular brand i should invest because i know at stang suspension they have steeda balljoints and other quality stuff. Just want the best for my car. appreciate any advice. thanks!
Sep 1, 2015 08:16 PM
