tb spacer is worthless unless you get your intake manifold ported and if you do that ya might as well p&p everything esle
your better off gonig with under drive pulleys
ok, i was lookimg at some UDP the one at autobadges comes with just the crank pulley for like $75, and one from mustangsunlimited comes with the carnk, waterpump, and alternater puleeys for $90. they both say they give the same amount of hp. which one should i go with?
They're worthless on a ported intake. Tell me this, if you have a 99-04 V6, and you port your intake opening to 65mm and you get a TB spacer, the TB spacer is gonna really hurt you because it's opening is still 60mm, so it won't help at all, well, other than lightning your wallet. In short it's complete junk.
