Check Engine Light??
Old Jan 2, 2007 | 08:52 PM
Robby7979's Avatar
Robby7979
Default Check Engine Light??
Hey guys, i got a 04 v6 mustang convert.
My cousin bought me a aftermarket air filter to put it on my car. We put it on, with out the air flow sensor installed. Now my check engine light is on(obviously) , since then I put the original air filter back in, and connected the air flow sensor. The check engine light did not go way. My question is, will that light stay on until I reset the computer...or should it naturally turn off once the problem is fixed, and if there still is a problem, the light will stay on?
Thanks for the input
Rob
Old Jan 2, 2007 | 09:36 PM
Xemeth's Avatar
Xemeth
Default RE: Check Engine Light??
Try un hooking the battery for a bit. Then try again.
Old Jan 3, 2007 | 01:29 AM
Jefferson's Avatar
Jefferson
Moderator
+1
Also, make sure everything is seated properly and the sensor is fully pluged in.
Old Jan 3, 2007 | 01:44 AM
ByPopularDemand's Avatar
ByPopularDemand
I think if you drive the car 3 times with the problem fixed the light will turn off
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
