Transmission Fluid Change
Old Jan 10, 2007 | 06:35 AM
ecuadorspimp's Avatar
ecuadorspimp
Default Transmission Fluid Change
I think its time for my stang to get its tranny fluid changed. Agree? It only has 35,000 miles. Its an automatic so what brand should I use? And what will I need to get, in order to do it myself or should I just take it to the shop where they will charge me 100? Thanks for the help
Old Jan 10, 2007 | 06:45 AM
SilvrStang's Avatar
SilvrStang
Default RE: Transmission Fluid Change
Yeah nice idea. I`m actually do my tranny flush and tranny fluid change when I install my shift kit at the end of this month. I would go with Royal Purple MAX fluid. American Muscle carries the product,heres the link http://americanmuscle.com/royal-purp...ion-fluid.html
If u wana do it yourself I really dont know how difficult it would be but your best bet is to get a HAYNES manual or go to this website and find a manual for your car to see how its done.
http://www.genuineservice.com/genuin...loveboxresults
Good luck pal!
Old Jan 10, 2007 | 12:31 PM
jpacetti's Avatar
jpacetti
For starters make sure you use the right type of tran fluid. For some models its Mercron, for others Mercron V. The Hayes manual specifies... I like Castrol brand myself. Also don,t forget to change the filter. If you have a way to get under it its easy. I just did mine on a pair of ramps. Also took the time to clean my pan. Took about an hour. Good luck
Old Jan 11, 2007 | 12:28 AM
ecuadorspimp
how many bottles should i get?? and in the long run would it be cheaper to let the shop do it for me??
Old Jan 11, 2007 | 03:09 AM
baddog671's Avatar
baddog671
100 bucks! holey crap they are rapeing u! The shop I work at charges 45 bucks and that would still make about a 15 buck profit off your car. I believe there is like 4 quarts but dont qoute me on that.
Im gonna do this too on my next oil change since its been 126k since it was serviced...
Old Jan 11, 2007 | 03:46 AM
ecuadorspimp
hmm, im gonna double check on the prices but i wanna do it soon since im takin a road trip to VA
Old Jan 12, 2007 | 02:37 PM
jpacetti's Avatar
jpacetti
As a standard I just go ahead and buy a case which runs between 25-35 dollars. I only used 6 quarts.Just add fluid till it shows up on the dip stick. Crank up the car and run it through the different gears. Then recheck your fluid level while running.If you change the fluid in the torq converter you will need to add more but this requires removing the transmission. At least I don't know another way... You can get the filter and gasket for about 10-15 dollars. It may be easier to let someone else do it. But I hate letting other folks touch my Stang. And I like to clean everything up in the process and I doubt they do that at Jiffy Lube. Your car.. your risk.. By the way it's a good practice to do this every 30K. Tran fluid is a whole lot cheaper than a new transmission. Good luck.
Old Jan 12, 2007 | 03:23 PM
ecuadorspimp
Done. Paid 70 bucks. not bad, I guess. New Transmission flkuid, new filter, and they cleaned the pan. Not bad I guess. Feels much better with the shifting
mtgldr
Feb 3, 2024 09:00 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
vintageaion
Sep 8, 2015 10:45 AM
