quick question
Old Jan 11, 2007 | 09:42 AM
stang_girl_03's Avatar
stang_girl_03
Default quick question
i am going to be putting stage 2 comp cams in my car in the next few weeks. i already have full bolt-ons. i know that i should get a dyno tune and i am planning on it. The question that i have now is DO I HAVE TO UPGRADE MY REAR END. i drag race somwtimes. only like 2 passes every other wekeend and i never run slicks
Old Jan 11, 2007 | 09:50 AM
ecuadorspimp's Avatar
ecuadorspimp
Default RE: quick question
thats a good a$$. i think i would just to launch better off the line. but im not the expert. i would do it though cuz it would benifit the ride.
Old Jan 11, 2007 | 10:44 AM
00raging stang's Avatar
00raging stang
abouthow much performance do you get out of a bigger cam
Old Jan 11, 2007 | 10:52 AM
disturbed471985's Avatar
disturbed471985
Just adding cams will not give you much more power then u already have so no ur rearend can be left alone. Id get gears if you dont already. Plus like you have already said NEVER RUN SLICKS.
Old Jan 11, 2007 | 11:38 AM
stang_girl_03
ok thanks
Old Jan 11, 2007 | 11:45 AM
deezelnut's Avatar
deezelnut
I ♥ Acer
ORIGINAL: disturbed471985
misimformed. the cam is one of Ford's ways of keeping power down in the v6. it is weak. but go with a full powerpak. it will make a huge difference. then get some 4.10s and a detroit.
Old Jan 11, 2007 | 11:48 AM
disturbed471985
So ur saying adding cams to this v6 will be to much for her stock rearend??? cause that was here question and ummmm no im not misinformed
Old Jan 11, 2007 | 11:53 AM
deezelnut's Avatar
deezelnut
I ♥ Acer
she won't break the rearend. the tires will spin before that happens. i meant a cam is an underrated mod for the sixxers.
Old Jan 11, 2007 | 11:56 AM
disturbed471985
The cam might be an underrated mod but i was just answering her question would adding cams f her rear up! But anyways hows life?
Old Jan 11, 2007 | 12:04 PM
deezelnut's Avatar
deezelnut
I ♥ Acer
life is awesome. i'm alive in a ****ed up country with a different language and no car. but a cam won't cause the rear end to die. the 7.5 is actually a lot stronger than people give credit for. the weakness is the 7.5 T-lok
