underdrive pulley
Patience grasshopper, lol.
I'm new but from what I've been reading, Autobadges is pretty good and for only $200 you get this one pulley, and you can rent a balancer from a local auto parts store or buy it for like $15.
I did see a kit on RPM Outlet though that had more pulleys for about the same price but they are apparently not good... [:'(]
ORIGINAL: Cmpfreak88
Yes that picture is exactly what you get plus the shortened belt if you get it from autobadges.com (if you look in his 5000 post thread, he is giving discounts today). The black part is the pulley and the silver part on the back is the harmonic balancer but they go as one unit.
If you do the install yourself you will need to rent a pulley puller from most autoparts store and as mentioned they are cheap.
If you have any questions feel free to ask, there is also a write-up on the installation in out Tech Article sticky at the top of the section. Here is a link.
i think the reason he is aksing is because the 99-early 00 are different from late00-04. you need to go outside and look at your car and find the pully thats bein replaced. if it has a little bump thing in it...the one in the pic does...see it on the bottom? if it has it you need the 99-00 pulley. if you dont have it you need the 01-04 pulley. but yea that looks like the right one.
