spend ur money on something else besides airbags, i have an eibach pro-kit lowered 1.5" from stock height and have a set of eibach camber bolts along with them
ok so if i bought an Eibach Pro kit for like $250 or however much the run for...is that absolutely all i need to lower it 1.5?..
depends. you could be ok or you could need some alignment. you will have to get it check sometime after you lower it and if its off then you will need some camber bolts. they will fix it for ya. but if you dont want those you coudl spend the extra cash and get the cc plates. you can get camber bolts and stangsuspension.com
