D2D SHIFT?
Old Jan 19, 2007 | 12:45 AM
nozracer's Avatar
nozracer
Default D2D SHIFT?
Hey i was posting this to see if anyone could explain in detail the D2D shift with specifics, maybe a video? But specifics would be good Thanx
Old Jan 19, 2007 | 12:59 AM
v6stang07's Avatar
v6stang07
Default RE: D2D SHIFT?
dont have a vid but here ya go, with air and traction control off, firmly give your car gas and mash the petal to the floor, not immediatly cause u will end up semi bogging up the engine, when u hit 4600 rpm's shift down to 2 with the petal still to the floor, if done right u will chirp 2nd, then when u reach 5400 rpm's shift back up to drive u wont have to push the button this time on the shifter, u wont chirp 3rd then u have done all the hard work the rest is up to the car. it takes some time to perfect but basically when shifting from d to 2 u are trying to time the shift to where u shift just at or right before redline, the auto will have a bit of a delay so thats why i say 4600 and thats what i was told when i learned. good luck and after a couple runs u will have it down. dont do it too much tho and mess up ur tranny
Old Jan 19, 2007 | 01:44 AM
Xemeth's Avatar
Xemeth
You won't mess up the tranny if you do it right. It's programmed in the computer. Granted pushing the car hard at every red light will mess up something eventually, but the D2D shifting is pretty safe.
Old Jan 19, 2007 | 02:08 AM
jovez's Avatar
jovez
Ya, it wont mess up anything, all its doin is increasing the line pressure in the tranny. kinda like a poor mans shift kit
Old Jan 19, 2007 | 02:20 AM
cobra232's Avatar
cobra232
i wouldn't do it from every stop. only do it ocassionally. better off safe than sorry.
the trick is to master when your car shifts into 2nd at WOT and pull it from D back into 2nd just before the trans would have shifted itself
Old Jan 19, 2007 | 04:50 AM
MustangMike2001's Avatar
MustangMike2001
blah who cares
Old Jan 19, 2007 | 12:15 PM
mustangman02232's Avatar
mustangman02232
ORIGINAL: cobra232
im semi testing that as we speaknot quite every stop light, but alot more then it should
its been fine for the last 13k
Old Jan 19, 2007 | 01:58 PM
ByPopularDemand's Avatar
ByPopularDemand
Why do that from lights...save it for the track
Old Jan 19, 2007 | 02:02 PM
mustangman02232
ORIGINAL: ByPopularDemand
im not flooring it from every light, just sport shifting and d2ding about 4000 atleast once a drive
Old Jan 19, 2007 | 02:06 PM
ByPopularDemand
Lol practice makes perfect i guess
