Eibach Installation
Old Jan 21, 2007 | 07:08 PM
v6stang07's Avatar
v6stang07
Default RE: Eibach Installation
YES on the alignment, that mustangworld is the same how-to i used for my eibachs, its a great write up. Mine took a little longer but i also painted my calipers and some other stuff
Old Jan 21, 2007 | 08:32 PM
drifts14x's Avatar
drifts14x
Needed to know, since nobody bothered to mention it, how much of a drop can the stock struts take? In the picture it surely didn't look as though the front or rears were Bilstein/KYB/Tokico Units, at what drop level will the stockers no longer hold? Also, is it necessary to buy some type of camber/caster adjustment piece, as every Honda/Nissan/Toyota I've ever dropped has required such. I would very much appreciate the info, I know I should just search, but perhaps this information could find its way into a sticky to save people time in the future.
Old Jan 21, 2007 | 08:37 PM
MustangKid89's Avatar
MustangKid89
bump- rock the catbox
Old Jan 21, 2007 | 11:58 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
How did it go, you should've been long done by now? If you're stuck post up and I'll PM you my number and walk you trough it.
Ryan
Old Jan 22, 2007 | 11:15 AM
stang_girl_03's Avatar
stang_girl_03
thanks guys...we got it dont in about and hour...pics will be up tonight
Old Jan 22, 2007 | 04:50 PM
v6stang07's Avatar
v6stang07
drifts 14x, i dont really know how much u can compress the stock shocks/struts but many i know that u can drop 1.5" and they be fine even tho shorter aftermarket ones would give a better ride, rule of thumb is that if u drop 1.6" or more u need cc plates, 1"-1.5" u need a camber bolt kit, and less than that u just need to align ur car. u also need an alignment with all these drops.
glad ur install went good, we def want some before and after pics
mtgldr
Feb 3, 2024 09:00 PM
PullTab
Oct 30, 2015 08:46 AM
Sep 10, 2015 08:39 PM
RWHEELS
Sep 5, 2015 03:42 PM
