Wrong oil, how does this affect motor
Old Jan 22, 2007 | 05:41 PM
HelloKitty_Cupcake's Avatar
HelloKitty_Cupcake
Default Wrong oil, how does this affect motor
If someone had added the wrong weight oil to my motor, how and what will it affect?
Old Jan 22, 2007 | 05:45 PM
v6stang07's Avatar
v6stang07
Default RE: Wrong oil, how does this affect motor
if it is heavier oil none really, it may actually last a bit longer and the engine will have to work a tad harder and it will be able to work longer and at higher temps but its no biggy, what is in you car??
Old Jan 22, 2007 | 06:01 PM
Baron von Munchausen's Avatar
If a heavier weight oil, (e.g. 10W-40 for instance) was added instead of a light weight oil (e.g. 5W-20 for instance) the engine would be somewhat less lubricated, particularly at a cold startup. Tolerances on late model engines are consideralbly tighter than those of 20 -30 years ago, so they generally require a lighter weight oil. If you simply added a quart, rather than did a full 5-quart oil change with it, the effect would obviously be much less.
If you've any doubts, get it changed to the correct weight. Oil is cheap compared to the worry factor from not doing so.
Old Jan 22, 2007 | 11:16 PM
HelloKitty_Cupcake
the guys at jiffy lube put in 10w30....a full 5-qts, im going to put 5w20 back in soon, umm thats not causing my car to sound like a lawnmower after initial startup, will it? cause its been making a clicking/ticking noise almost like a lwanmower right after it starts up, then it quiets down.
Old Jan 22, 2007 | 11:22 PM
baddog671's Avatar
baddog671
If your engine requires 5w20, and they put in 10w30, change it out.
Also, find a new place to change your oil...
Old Jan 22, 2007 | 11:27 PM
Clif Brohn's Avatar
Clif Brohn
I run 10W30 during the summer, if its cold in your area right, throw some 5W20 in it for a couple of months or until it warms up. THEN put 10W30 in it once it gets hot again. Best thing you can do for your car.
Old Jan 23, 2007 | 02:32 AM
v6stang07's Avatar
v6stang07
i didnt even think about the cold, i live in south GA and its hot right now, if it is cold i would def change it out but if not, u can actually run at higher temps. also change ur own oil next time to make sure its done right
Old Jan 23, 2007 | 03:22 AM
cominus's Avatar
cominus
I use the heavier oil in my car, well with the heat in my city, like around (100+F degrees) in the summer, it's better for your engine so that the oil doesnt over heat too quickly and get all sludgy, but for the winter use the lighter oil.
Old Jan 23, 2007 | 09:19 PM
Not true, use 5W-20 year-round for '99-'04 Mustangs, regardless of where you live. The practice of using heavier weight oil in the summer or in hotter climates might have had some validity forengines made 20 - 30 years ago, but not for those made today.
Old Jan 23, 2007 | 10:39 PM
jthorn9's Avatar
jthorn9
The Godfather
Not to be rude or anything.......... but........[sm=icon_rtfm.gif], it tells you exactly what oil you should be running in your car.
