V6 Power
Old Jan 24, 2007 | 06:17 PM
indisposible_teens's Avatar
indisposible_teens
Default V6 Power
I have a 1998 V6 mustang with a single port. Would I be able to switch to the Dual Port that came on the 1999-2004's and if possible how much would it cost?
Old Jan 24, 2007 | 06:19 PM
JoJo96Vert's Avatar
JoJo96Vert
Default RE: V6 Power
It is possible, but I cant remember what the estimated price on it was. Im thinkin its about 1500 or something in that area, but someone else will chime in with a closer guess if Im off.
Old Jan 24, 2007 | 06:37 PM
BillyBobJoe's Avatar
BillyBobJoe
1500 sounds about fair, new heads and at least a lower intake manifold if not upper and lower. keep an eye on the junk yard for crashed 99 and ups...but also, with a single port, you can pop on a S/C from a thunderbird? easier...think about it...
Old Jan 24, 2007 | 06:40 PM
deezelnut's Avatar
deezelnut
I ♥ Acer
ORIGINAL: BillyBobJoe
you can also look for 97 up f150s. i am pretty surethat is when they started to have split-port
Old Jan 24, 2007 | 07:00 PM
mustangman02232's Avatar
mustangman02232
f150s never had single port, they went to the 4.2 in 98 from the 300 I6
Old Jan 24, 2007 | 08:44 PM
jthorn9's Avatar
jthorn9
The Godfather
Yes you can, http://www.rpm-mustangs.com/ has all you need for the swap. If you get just a basic swap kit, the whole thing will cost around $800, if you get everything needed, and a little extra, it's around $1250 for the kit, if you go all out, and get a fully ported system, it's gonna be around $1800 (best buy). Not sure about any shop charges on install, so you should look into that, but if you know a little bit about cars, or know a mechanic, then I'd install it myself, just be prepared to have your car down for about a week for the swap.
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
