How do u take off center paneL?
Man I cant take my damn sterio out, it's stuck, I have the little keys to get it out but I only found one, I didnt even know what it was for until I found the manual. I wanna paint mine too, should I try sanding my plastic first? Will the little air vents, the passanger side and driver side come off easily with a screw driver?
ORIGINAL: cominus
are you talking defrost vents? they have clips on each side, work you ScrewDriver(SD) in on one side and push in slightly until you and pull it up a little, then do it to the other side and it should pop out.
Most IMPORTANT TIP!!!!!!!
Please Keep The Spray Paint Going.Dont let it sit in one spot otherwise ur gona mess everything up and its gona look like ****. Spray(not too cllose up)
