reverse grinds???
Old Jan 28, 2007 | 03:04 PM
benz660r's Avatar
benz660r
Default reverse grinds???
hey i have a 2002 v6 5 speed mustang and when backing up it sound like a grinding noise but is in gear almost sounds like chattering? ANy one know why htis could happen or how to fix it?
Old Jan 28, 2007 | 04:01 PM
98ponycar's Avatar
98ponycar
Default RE: reverse grinds???
There's nothing to worry about. Manual transmissions have two types of gears. Spur and helical. Spur gears have a straight cut tooth design. They're built stronger, and they're used for reverse. They make noise, whereas helical gears are cut at an angle in relation the the gear axis, which means they're much quieter, but not as strong as a spur gear. The noise you're hearing is perfectly normal.
Old Jan 28, 2007 | 04:11 PM
MustangKid89's Avatar
MustangKid89
put the car into 5th gear with the clutch still down to stop the rotation before you put it into reverse this will stop the grinding of the gears!
Old Jan 28, 2007 | 04:12 PM
bjm3.8's Avatar
bjm3.8
Just a perfectly normal Ford Transmission.
Old Jan 28, 2007 | 04:15 PM
98ponycar's Avatar
98ponycar
ORIGINAL: MustangKid89
First of all, reverse is synchronized, so putting it in fifth isn't going to do anything for it. Second, he doesn't hear anything when he's going into gear. He hears the spur gears running as the car is moving while in reverse. It's 100% normal.
Old Jan 28, 2007 | 11:23 PM
benz660r's Avatar
benz660r
no much worse than the normal nosie.. it sound like a bad bearing? Could it be a bad gear how hard is it to change a gear?
Old Jan 28, 2007 | 11:31 PM
HornyHornyHippo's Avatar
HornyHornyHippo
That damn reverse man, they did a weird job on making em. Sometimes if i go straight from manual to reverse i cant get it into Reverse even if i use all my force, yet if i go to fifth then reverse it slides right in. Also itll click into place yet still grind the gears every so often. Nothing TO major, its just weird how sometimes it wont let me go into reverse. (All from a dead stop, and with the clutch in all the way obviously)
Old Jan 28, 2007 | 11:34 PM
GregoryA44's Avatar
GregoryA44
mine you just push a button in and pull down lol gotta love autos baby!
Old Jan 28, 2007 | 11:36 PM
HornyHornyHippo
ORIGINAL: GregoryA44
How could you say such blasphemy!
KingRando
Oct 2, 2015 08:06 AM
JDWalton
Sep 24, 2015 08:47 PM
foxdude
Sep 24, 2015 08:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
