turbo kit ?
Old Jan 29, 2007 | 07:14 PM
notchbackmatt87's Avatar
notchbackmatt87
Default turbo kit ?
hey got a 1998 fors mustang v6 cold air and exhuast i pciked up a turbo i need all the piping intercooler **** like that i need to know what else ill need how much horses ill be looking at along with money and other mods i should do while turboing a stang
Old Jan 29, 2007 | 08:19 PM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: turbo kit ?
you will have to take off the cia. you could possibly use it on the turbo, but you would have to modify it.
you can keep the dules, but will have to use basically a backwards y pipe to split it from 1 exahust to 2.
i believe you will need a new maf
that is basically all you need to run the turbo, but the most psi you can put through it would be 4.4
get 42 lb injectors and a focus fuel pump and you can up the psi more.
Old Jan 29, 2007 | 09:33 PM
notchbackmatt87
i wanna run alot of boost how could i do that
Old Jan 29, 2007 | 09:38 PM
l_shizzle_l
how much boost are we talking about here....
and your internals are limited on horsepower, not boost.
Old Jan 29, 2007 | 09:58 PM
notchbackmatt87
i dont kno much how much could i possibly run with my stock block not blowing myself up lol
Old Jan 29, 2007 | 10:01 PM
98Ga's Avatar
98Ga
you can run a pretty good bit on the block its just the internals that you will have to replace
Old Jan 29, 2007 | 10:11 PM
notchbackmatt87
can u tell me the things i will have to replace and how could i get to around 300 horses
Old Jan 29, 2007 | 10:14 PM
notchbackmatt87
hey ppl im me i got aim i wanna talk bout turbo and stuff if u kno about it and wanna chat im me thanks so much xyankiesx
Old Jan 29, 2007 | 10:31 PM
l_shizzle_l
you should be fine with the 42lb injectors, focus fuel pump, and a tune.internals will be ok at 300 as well.
read this. should take you like an hour, but well worth it.
http://www.3.8mustang.com/forum/showthread.php?t=127526
a very good walkthrough. then ask any questions you have.
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
TCStangerv6
Oct 11, 2015 05:57 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
