pumping gas problems
Old Feb 10, 2007 | 05:16 PM
juan310's Avatar
juan310
Default pumping gas problems
everytime i try to pump gas it just keeps shuting off after like 3 seconds. so i gotta keep holding it when it clicks off. it wasnt like this before. i could pumps gas at any gas station with no problem now it happens everywhere. i know the problem is with my car (2000 v6/83000miles) and not the pumps. what could it be?
Old Feb 10, 2007 | 05:23 PM
Xemeth's Avatar
Xemeth
Default RE: pumping gas problems
It could be the gas pumps and you're just extremely unlucky. I used to work at a gas station, and this would happen from time to time. Best thing to do is hang up the nozzle and try again.
Old Feb 10, 2007 | 05:26 PM
hookedonkronik's Avatar
hookedonkronik
are you sure you're shoving the nozzle all the way in? It seems like when you do it half-way it shuts off like that. Just my own observation though
juan310's Avatar
juan310
i really thinks its my car.....ive been to a bunch of different gas stations and the exact same problem. its like i can only pump gas 30cents at a time
Old Feb 10, 2007 | 05:30 PM
juan310's Avatar
juan310
ive been pumping gas for quite some time and havent had a problem like this with other cars. of course imma jam the nozzle all the way in but it still doesnt work. this has been going for almost a month and i think it will get worse
Old Feb 10, 2007 | 06:53 PM
95stangs's Avatar
95stangs
ORIGINAL: juan310
lol
Old Feb 10, 2007 | 07:29 PM
warheed's Avatar
warheed
check your gas filler tube for any debris or pluggage.. only advice i have.. use a plumbing snake with a rag on it to clean out that tube
Old Feb 10, 2007 | 08:56 PM
90lxstang's Avatar
90lxstang
i have the exact same problem with my '90 and it sucks! i can't figure it out either. usually it starts working right after a few gallons are in. i hope someone can help us out.
Old Feb 10, 2007 | 08:57 PM
Durr727's Avatar
Durr727
Does it click off when you reach the maximum limit for the tank? Or does it begin to overflow out of the tank.
Old Feb 10, 2007 | 08:59 PM
v6stang07's Avatar
v6stang07
i know in central florida where my grandmother lives most stations around there do that to save gas, i guess the figure if it is aggravating enough then u will just settle with the amount of gas that u have in the tank, i know its not her vehicle cause it does it to mine down there also, i could be that or if its your car then i would try and check to see if there is a blockage in the filler tube
