Pcv HELP!!
Old Feb 11, 2007 | 03:58 AM
baddog671's Avatar
baddog671
Default RE: Pcv delete kit?
PCV is meant to ventelate your crankcase. If you remove it your car will, run like total crap, decrease mpg, and leak more if you seal it. If your leaking, you apparently need new gaskets..
Old May 31, 2007 | 05:56 PM
ProvingGrounds's Avatar
ProvingGrounds
here's what I just did: I went to Advance Auto Parts and got 1) Mr. Gasket clear view fuel filter. 2) Purelator PCV Valve. 3) a foot of 3/8 fuel line hose and some clamps. Cut the existing line between the valve and the cover and install the filter in between using the hose and clamps. Change the valve while you are at it if yours is old. Total cost is about $15.
Old Jun 2, 2007 | 07:38 AM
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: baddog671
the car will run just fine if you use breathers. i had mine deleted for about a week and the car ran perfect...the problem with it is that it smells like a$$. when sitting at a stop light you can smell the crap commin out of the valve covers through the breathers.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
