Engine Problem
Old Feb 13, 2007 | 04:19 PM
v6kid07's Avatar
v6kid07
Default RE: Engine Problem
im running 89 octane and when i fill up my tank and start up the car i can smell the gas through the vents and i know thats not normal
Old Feb 13, 2007 | 04:40 PM
raz54's Avatar
raz54
Are you buying cheap gas? Some stations that sell gas cheap their gas isn't very good and I've had detonation from it which is what your problem soulnds like since it only does it when you floor it. How about when you are in lower gears so the enginge is not bogging at all, does it do it then?
Old Feb 13, 2007 | 05:19 PM
v6kid07's Avatar
v6kid07
from 0-3000 rpms call is slower but minute it hits 3100 it flys
Old Feb 13, 2007 | 05:23 PM
v6kid07's Avatar
v6kid07
when car hits 3000 is when the ticking begins
Old Feb 13, 2007 | 05:28 PM
cobra232's Avatar
cobra232
i highly doubt it's a lifter as they almost never go bad. most likely it's a slight crack in the header as they were known for that. also the 3.8 has a reputation for having a slightly noisy valvetrain which is all it could be also. like another said if it's at WOT it may be detonation. try some higher octane fuel and seafoam the intake through the PCV port. the PCV's are known to allow too much oil through into the intake and it leaves deposits on the intake valves which will make a noisy situation as that valve may be slower to open and close and the rocker may be slapping against it. we are only talking about a couple of thousanth's of an inch play but enough to make a noise at highrpms.
could have a slightly loose sparkplug too. there are alot of things that can cause your symptoms but the lifters are way down on the list of what i would check first
Old Feb 14, 2007 | 02:50 AM
v6kid07's Avatar
v6kid07
i dont know how to use seafoam can you give me directions how and my headers are heddman shortys so i know their fine and tight ill upgrade my gas my car does feel slower
Old Feb 14, 2007 | 07:03 PM
v6stang07's Avatar
v6stang07
i bet mine is the exhaust leak cause i know i have one, ur could be leakin in another place
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
