Engine Problem
Old Feb 13, 2007 | 03:49 PM
v6kid07's Avatar
v6kid07
Default Engine Problem
Ok my engine has been making a tick tick noise at wide open throttle and its starting to worry me that something big is about to go wrong. The rapid tick tick noise only happens when i floor it but doesnt make it when im normally driving. Please tell you guys have ideas
Old Feb 13, 2007 | 03:53 PM
v6kid07's Avatar
v6kid07
Default RE: Engine Problem
i forgot to add that my car has 46k on odometer if that means anything and its a 1999
Old Feb 13, 2007 | 03:54 PM
v6stang07's Avatar
v6stang07
I think i have the same problem, i havnt really looked into it but im hoping its just a vaccum hose or sumthin since i cant hear it at idle.
Old Feb 13, 2007 | 03:56 PM
cisurfer's Avatar
cisurfer
mine does it when im under hard accel....liek in 5th gear at 50mph and hittin the gas hard it will tick...i think its the exhaust manifolds
Old Feb 13, 2007 | 03:58 PM
Jugador's Avatar
Jugador
my guess is that it's an exhaust leak, but a lifter tick will make noise under the same conditions as an exhaust leak i believe (but it should be audible even at crusing speeds).
try to pinpoint where in the engine bay it's coming from and check the exhaust for loose connections, missing gaskets, or leaking welds. i think the most common problem for you sixers is the welds on the exhaust manifold.
Old Feb 13, 2007 | 04:01 PM
v6kid07's Avatar
v6kid07
i dont think its an exhaust leak because i have had one and got the whole car inspected for more when it was up on a lift
Old Feb 13, 2007 | 04:03 PM
cisurfer's Avatar
cisurfer
it woudl be right at the headers (manifolds sorry)
Old Feb 13, 2007 | 04:06 PM
v6kid07's Avatar
v6kid07
im afraid it might be a lifter and thats a big money job
Old Feb 13, 2007 | 04:10 PM
Jugador's Avatar
Jugador
ORIGINAL: v6kid07
well then you're going to have to be more specific so people aren't just guessing at problems they don't have enough information about.
have you recently put on a 93 octane tune and run lower grade gas in it?
does putting a screwdriver on the valve cover amplify the tick? (you might need to put your ear on it to hear it through the screwdriver)
have you checked the manifolds and confirmed or disconfirmed any leaks or at least possibilities that that's where the sound is coming from?
Old Feb 13, 2007 | 04:12 PM
cisurfer's Avatar
cisurfer
if its a lifter in my car looks liek im getitn a cam and new heads haha
