Engine rebuild kit?
Old Feb 17, 2007 | 07:23 PM
crysalis_01's Avatar
crysalis_01
Banned!
Default Engine rebuild kit?
Sitting on over 215,000 miles can be unnerving. So I'm going to take a week or so off of work and rebulid the engine early June.
Question: Does anyone here know if there is a rebuilt kit (bearings, gaskets, head bolts, etc.) all together for an sn-95 or willl I have to get all that stuff seperate?
Old Feb 17, 2007 | 09:02 PM
95stangs's Avatar
95stangs
Default RE: Engine rebuild kit?
not sure...but i would just save up and put the split port motor in...ive got 153k on my car and for the money it just seems smarter to get a newer motor that has a lil more hp
Old Feb 17, 2007 | 09:40 PM
98Ga's Avatar
98Ga
i want to do the same thing i have 187,000 i know you havent found it yet but do you know about how much it will cost?
Old Feb 17, 2007 | 09:46 PM
95stangs's Avatar
95stangs
well iam eventually getting a 02 v6 for my 95 for $600and then another $200 for the modified fuel rail and etc...then i have install which iam not sure but that really always depends on who ya know but i figure 800 for a more reliable motor and 40 more rwhp isn't bad
Old Feb 17, 2007 | 09:49 PM
98Ga's Avatar
98Ga
im selling mine as soon as i get out of high school but i want the engine to be in good conditino with that many miles on it, i dont think the owner before me kept up with the engine to good
Old Feb 17, 2007 | 09:59 PM
95stangs's Avatar
95stangs
ill probably end up selling the motor, tranny and rearend as soon as i get the 8.8, T-5 conversion, and splitport motor which will probably be a while but a guy at work said he wanted the motor for his escort so...
Old Feb 17, 2007 | 10:26 PM
98ponycar's Avatar
98ponycar
Yes they make a rebuild kit that includes everything you will need to overhaul the engine, but why would you want to? 215k is no big deal. If you drive the car right and maintain it, you will have absolutely no problem getting 400k out of it. Mine has 242k, and I don't see a problem getting 400k out of it. I replaced the headgaskets at 200k, and saw absolutely no signs of wear on the cylinder walls. From what I could see of the camshaft through the lifter galley, it was great.The oil pan was cracked when I got the car. I replaced the pan. The bearings were great. You should have no problems with your engine unless it has been neglected.
Old Feb 17, 2007 | 10:33 PM
baddog671's Avatar
baddog671
ORIGINAL: 98ponycar
Cant say the same about those crappy Ford trannies though
Old Feb 17, 2007 | 10:37 PM
98ponycar's Avatar
98ponycar
I wouldn't be so sure. They may not go 400k, but when I swapped my auto to a manual at 215k, it had no problems at all. It had never had any major work performed to it. Only regular fluid and filter changes.
Old Feb 17, 2007 | 11:22 PM
95stangs's Avatar
95stangs
yeah i can't really see a auto tranny going to 400k...i still don't see how i got to 153k i figured it would have craped out already
