DPFE sensor
Old Feb 20, 2007 | 10:49 PM
Baron von Munchausen's Avatar
Default RE: DPFE sensor
ORIGINAL: cobra232
it's turbulence through the MAF. you either need to put a screen infront of the sensor or go back to the stock intake setup
if the screen doesn't work then try a straight filter mount to the MAF. It is a fender CAI correct? the 90 degree bend in CAI's are known to give turbulence at low speeds like at idle or coming up to a stop sign. too much turbulence and the meter gives incorrect fuel air demands and the car stumbles and stalls
The K&N CAI is essentially a straight mount to the MAF. I mentioned the screen because that was a common problem with the K&N Aircharger used on Mach 1's, including mine. Many found that re-installing the screen cured the problem. I didn't know if that issue might possibly have extended to V6 models as well, but would seem possible. That said, we've used a K&N FIPK II CAI on my wife's '04 V6 for over two years with no stalling issues, and no screen installed.
Old Feb 20, 2007 | 11:32 PM
cobra232's Avatar
cobra232
ORIGINAL: Baron von Munchausen
ORIGINAL: cobra232
every car is different though and i would lay $50 that he is having turbulence issues in the MAF.
there is an easy way to tell. just put the stock intake and filterbox with MAF back on the car and if it runs fine you know it's turbulence
Old Feb 21, 2007 | 10:21 PM
ORIGINAL: cobra232
ORIGINAL: cobra232
I definately agree, because the sypmtoms he described fit the stalling issues I had almost to a "T"
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
