RPM Limiter and racing
Old Feb 24, 2007 | 03:24 PM
wiksta's Avatar
wiksta
Default RPM Limiter and racing
I have a 99' V6 mustang, 5 speed. I added duel exhaust but other than that its stock. I have always been scared to rev the RPM's above red line. My friend said that the car limits the RPM's electroically. Does anyone know if this is true on my year and what RPM is the limit? Also does the limit shut the fuel off or does it kinda bounce off the max RPM? Is there any possibility i will blow my engine by hitting the limit? I dont have much knowledge about this so sorry for being so crude.
Secondly, i am going to take my car to a drag track. Its an eighth mile. Does anyone know what are the best shift points? What should i have my RPM's at to get the quickest start off the line and also going into second and third? Any tips are helpful. Thanks.
Old Feb 24, 2007 | 03:50 PM
cisurfer's Avatar
cisurfer
Default RE: RPM Limiter and racing
off the line rev to about 1500 and release the clutch pratice before becuz you prolyl win spin you tires.....shift points are just aroudn redline 5200rpms
Old Feb 24, 2007 | 03:53 PM
mustangman02232's Avatar
mustangman02232
its set at 5800 rpms on split ports, ideal shifting is about 5500 rpms
Old Feb 24, 2007 | 04:02 PM
wiksta's Avatar
wiksta
Whats split ports? Is there any chance of damaging my engine by reving it that high?
Old Feb 24, 2007 | 04:05 PM
gyea's Avatar
gyea
ORIGINAL: wiksta
maybe if your launching at 5800 rpm
Old Feb 24, 2007 | 04:10 PM
wiksta's Avatar
wiksta
ORIGINAL: gyea
ORIGINAL: wiksta
im not going to launch at 5800 rpm. i know that will spin the tires. i want to know what rpm is the best for the quickest starts and also if i rev it to 5800 when shifting to second or third or just reving it will that damage the engine?
Old Feb 24, 2007 | 10:57 PM
nozracer's Avatar
nozracer
how would this apply to an automatic? whats the highest you could rev on neutral **** to D when racing?
Old Feb 24, 2007 | 11:52 PM
l_shizzle_l's Avatar
l_shizzle_l
for the quickest starts, go between 1500 and 2500. shift a little bit after redline, arround 5375 is what i try to hit and works really good for me
Old Feb 24, 2007 | 11:56 PM
fallfast90's Avatar
fallfast90
If you are just sitting there and revving, you will only be able to go to 4000rpms and then it will just bounce there. It will be different while driving though.
FivePointToTheOh
Mar 9, 2020 10:26 PM
uberstang1
Sep 20, 2015 06:42 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Mustangmalo
Sep 6, 2015 05:22 PM
